Does Angular Momentum Affect Linear Momentum in Physics Problems?
The discussion revolves around a physics problem involving a supply plane dropping a package into a sled, prompting a question about the relationship between linear and angular momentum. The key equation for solving the problem is the conservation of momentum formula, which states that the total momentum before the drop equals the total momentum after the package lands. Participants clarify that vertical and horizontal velocities are independent, and vertical motion does not affect the sled's final horizontal velocity. Concerns about potential trick questions from the teacher are noted, but the consensus is that the problem is straightforward. The focus remains on applying the conservation of linear momentum correctly to estimate the sled's mass.
jcurtis912
Near the South Pole, a supply plane going at 120 mph drops a 60 kg supply package into a sled that was initially at rest. After the package lands in the sled, the speed of the sled was found to be 30 m/s. Estimate the mass of the sled.
M1V1+M2V2=(M1+M2)V
Now i know that vertical velocity and horizontal velocity are independent of each other. So it would seem like i just plug, play, and solve for the unknowns. But this seems all too easy, like maybe the vertical motion has an effect on the final velocity. Anyone help?
Looks like a straightforward conservation of momentum problem. (Linear, not angular, of course.) Vertical motion won't factor in.
You know that's what i thought, but this teacher is brutal, always throwing trick questions, so i thought i was missing something here.
M1V1+M2V2=(M1+M2)V
Hi jcurtis912! Welcome to Physics Forums :smile:
Why would the vertical velocity have an effect on final horizontal velocity? The conservation of linear momentum clearly states that the momentum in one direction is conserved if there is no net force acting in that direction, and this holds for the given problem.
Edit : Seems I'm quite late...I left the screen open before submitting :-p
