Angular Speed of a star collapse
The discussion revolves around the angular speed of a neutron star resulting from the collapse of a larger star. The original star's radius and rotation period are provided, along with the final radius of the neutron star and its significantly higher density.
  • Participants explore the conservation of angular momentum and the relationship between density, mass, and volume. There are attempts to derive angular speed using proportions and equations involving moment of inertia.
Multiple approaches are being discussed, including whether to assume mass remains constant during the collapse. Some participants suggest that the density increase may not necessitate a mass change, while others argue that it likely does. There is no explicit consensus on the correct approach, but various lines of reasoning are being explored.
Participants note that the problem provides specific density information, which raises questions about its relevance to the solution. The complexity of the problem and the differing interpretations of the mass change assumption are highlighted.
Heat
Under some circumstances, a star can collapse into an extremely dense object made mostly of neutrons and called a neutron star. The density of a neutron star is roughly 10^{14} times as great as that of ordinary solid matter. Suppose we represent the star as a uniform, solid, rigid sphere, both before and after the collapse. The star's initial radius was 9.0×10^5 km (comparable to our sun); its final radius is 16 km.
If the original star rotated once in 31 days, find the angular speed of the neutron star.
Rotation of Original Star: (31 days/rev)(86400s/1day)(1rev/2pi) = 288770.73 rad/s
My first attempt was proportions :rolleyes:
[(288770.72 rad/s) / (9.0x10^5 km)] = [(w)/(16km)]
w = 5.13x10^10 :confused:
Conservation of angular momentum
but all that I am given is that the density is 10^14 greater than the before scenario.
Density is mass divided by volume.
The original density is [tex]\rho_0=\frac{m_0}{V_0}[/tex]
The new density is [tex]\rho_1=\frac{m_1}{V_1}=10^{14}\rho_0=10^{14}\frac{m_0}{V_0}[/tex]
Also, [tex]I_0\omega_0=I_1\omega_1[/tex]
Rearranging:
[tex]\omega_1=\frac{I_0\omega_0}{I_1}[/tex]
What is [tex]I[/tex] for a sphere?
[tex]I=\frac{2}{5} m r^2[/tex]
Now let's combine the equations:
[tex]\frac{m_0 r_0^2\omega_0}{m_1 r_1^2}=\omega_1[/tex]
Now to write mass in terms of density:
[tex]m=\rho V[/tex]
And you know the following:
[tex]\rho_1=\frac{m_1}{V_1}=10^{14}\rho_0=10^{14}\frac{ m_0}{V_0}[/tex]
Rearranging:
[tex]\frac{m_0}{m_1}=10^{-14}\frac{V_0}{V_1}[/tex]
Now that can be substituted in the other equation, giving:
[tex]10^{-14}\omega_0\frac{V_0 r_0^2}{V_1 r_1^2}=\omega_1[/tex]
u have ur math wrong (1rev/31days)(1day/86400s)(2PIrad/1rev)= answer.. <-- Wo
And the volume of a sphere is [tex]\frac{4}{3}\pi r^3[/tex]
[tex]V_0=\frac{4}{3}\pi r_0^3[/tex]
[tex]V_1=\frac{4}{3}\pi r_1^3[/tex]
[tex]\frac{V_0}{V_1}=\frac{r_0^3}{r_1^3}[/tex]
[tex]10^{-14}\omega_0\frac{r_0^5}{r_1^5}=\omega_1[/tex]
ahh exactly, nice.. and if u read above, i explain how to solve for Wo. Wo=(1rev/31days)(1day/86400s)(2PIrad/1rev)
wo = 2.35x10^-6
10^-14 ( .00000235)[(9.0x10^5)^5/(16)^5] = 13233.68
In two sig figs: 1.3 x 10 ^ 4
which is incorrect :O
It says the density increases. That does not (necessarily) mean the mass changes. I think you can assume that the mass is the same before and after the collapse.
the thing is, there is a good possibility that the mass will change.. because the density AND the radius changes... i=initial f=final
Pi=Mass(i)/Volume(i) Pf= (10^14)Pi ... now if we were to assume that masses are the same.. then let's call mass=x
Pi=X/(4pi/3(9.0×10^5 km)^3) Pf= (X/(4pi/3(16)^3)) we know that Pf/Pi=(10^14)
(X/(4pi/3(16)^3)) / (X/(4pi/3(9.0×10^5 km)^3)) must = to 10^14
after doing the math (the X's cancel out)
it comes out to be 1.8x10^14.. so masses must change
so masses do change, but it seems that Bill Foster already took that into account and simplified it to post #8 equation.
yet I went wrong somewhere. :(
I'm just saying if the "mass changing approach" doesn't give the right answer, maybe the simpler approach is what the question is really asking for. I think the 10^14 may just be extra information that is not needed to solve the problem.
You have [tex]I_o \omega_o = I_f \omega_f[/tex]
where
[tex]I_o = \frac{2}{5}MR_o^2[/tex]
[tex]I_f = \frac{2}{5}MR_f^2[/tex] assume the total mass stays constant.
You have [tex]\omega_o[/tex]
So put everything together, the mass cancels and you find [tex]\omega_f[/tex]
I could be wrong, of course. But did you at least try it this way to see what answer you get?
where
Maybe.. but its unlikely.. because the question wouldn't go into so much details about density.
if Heat gets the right answer using the "no mass change approach" then..well... I would say that the book/question is "technically" wrong.
However, there is some chance that Heat plugged the numbers incorrectly.. or something.. I am not sure.. let's see if Heat gets the right answer.
I know this is a very old post, but using hage567's method works. The mass does not change, and using his expression gives the correct answer.
15K
9K
  • · Replies 0 ·
  • · Replies 26 ·
