Angular Velocity: Formula for Max Velocity of Wood Block
To determine the maximum velocity of a wood block moving on a steel plate, the angle θ must be optimized based on the plate's velocity v. The block's velocity in the direction of interest (B) can be expressed as V_B = vcos(θ)sin(θ). To find the angle that maximizes this velocity, differentiate the expression with respect to θ and set the derivative to zero. Alternatively, trigonometric methods can also be employed to find the maximum value of V_B. Understanding these calculations requires a basic knowledge of calculus.
Brett bALL
This is my first contact and please excuse my limited knowledge of physics.
see attached sketch.
If the steel plate is moved along the steel table in direction A at a given velocity, what is the formula for the angle to achieve maximum velocity of the wood block in direction B.
Hi,
Im assuming that you have a basic knowledge of calculus.
If you assume that the plate moves in the direction A with a velocity v, then the block moves with a velocity vcos(\theta) along the plank in the downward direction.
The projection of this velocity along the B and A direction is vcos\thetasin\theta and vcos\thetacos\theta
V_B=vcos(\theta)sin(\theta)
Differentiate this expression wrt \theta and equate to zero to get max value.
Otherwise, you can find the max value of Vb using trig.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
