Answer: Calculating Relative & Absolute Uncertainty of R^-2
  • Thread starter Thread starter gcsm
    Relative
The discussion revolves around calculating the absolute uncertainty of a measurement raised to a power, specifically R to the power of negative two, where R is given as 4.000±0.002 m.
  • Exploratory, Assumption checking
  • Participants are attempting to clarify the distinction between absolute and relative uncertainty, with some confusion regarding the correct interpretation of the problem statement.
There is an ongoing exploration of the problem, with participants questioning the definitions and calculations related to absolute and relative uncertainty. Some guidance has been offered regarding the need to clarify which type of uncertainty is being sought.
Participants note a potential misunderstanding in the problem statement regarding the terms used for uncertainty, which may affect the calculations being discussed.
gcsm
Absolute Uncertanity
A distance R is measured to be 4.000±0.002 m
What is the absolute uncertainty in R to the power of negative two?
4^-2 = 0.00625
0.002^-2 = 250000
Im stuck at this question I have no idea where to go, any help would be appreciated!
umm you already gave the absolute uncertainty, it is 0,002m...
but I tried that, meaning 0.002 and that's not it, I also tried 250000 (using SI) and that isn't correct either...not really sure where to go...
Are you looking for the absolute or relative uncertainty? as in the thread title you say relative, but then in the problem description you say absolute.
The absolute is 0.002m that is 100%, then most probably you are looking for the relative uncertainty.
That is divide the absolute by the average.
sorry for the confusion, the question is as follows:
but wouldn't you have to do something to the +-0.002m?
10K
  • · Replies 21 ·
