Answer: Solving Three Step Gas Cycle Homework Problem
  • Thread starter Thread starter xmonsterx
    Cycle Gas
The discussion focuses on solving a three-step gas cycle problem involving a monatomic ideal gas. The steps include heating at constant volume, expanding at constant temperature, and cooling at constant pressure. Key equations discussed include the heat added during the first step, expressed as ΔQ₁ = [1.5*p₁*V₁*(AT₁-T₁)] / T₁, and the work done during the second and third steps, with W₂ = nRT*ln(V_f/V_i) and W₃ = p₁[(p₁V₁)/(Ap₁) - V₁]. Participants seek clarification on these calculations and their dependencies on initial conditions.
  • Understanding of monatomic ideal gas behavior
  • Familiarity with the first law of thermodynamics
  • Knowledge of the ideal gas law (PV=nRT)
  • Basic calculus for integrating work done
  • Review the first law of thermodynamics and its application to ideal gases
  • Study the derivation of work done in isothermal processes
  • Learn about heat transfer in constant volume processes
  • Explore graphical representations of thermodynamic processes on the pV diagram
Students studying thermodynamics, physics enthusiasts, and anyone tackling ideal gas problems in academic settings.
xmonsterx
A monatomic ideal gas has pressure p_1 and temperature T_1. It is contained in a cylinder of volume V_1 with a movable piston, so that it can do work on the outside world.
Consider the following three-step transformation of the gas:
1. The gas is heated at constant volume until the pressure reaches Ap_1 (where A >1).
2. The gas is then expanded at constant temperature until the pressure returns to p_1.
3. The gas is then cooled at constant pressure until the volume has returned to V_1.
It may be helpful to sketch this process on the pV plane.
Part 1-
How much heat DeltaQ_1 is added to the gas during step 1 of the process?
Express the heat added in terms of p_1, V_1, and A.
Part 2-
How much work W_2 is done by the gas during step 2?
Express the work done in terms of p_1, V_1, and A.
Part 3-
How much work W_3 is done by the gas during step 3?
If you've drawn a graph of the process, you won't need to calculate an integral to answer this question.
R = 8.31
Part 1-
I tried Q = p_1*V_1*(C_V/R) = 1.5*Ap_1*V_1 but I was told this is the final internal energy, not the change in internal energy. so I worked out that
Q = [1.5*p_1*V_1*(AT_1-T_1)] / T_1 but the answer does not depend on AT_1 or T_1
Part 2-
all I've got so far is
W = nRT*ln(V_f/V_i) = pV*ln(V_f/V_i)
but that's about as far as I get.
Part 3-
I got Ap_1*V_1 but this is what the value would be if it were coming from V = 0. So I re-arranged pV=nRT to eventually get
W = p_1[(p_1V_1)/(Ap_1) - V_1]
but this is also wrong how do I take into account the initial state, wouldn't I just be able to write W = (Ap_1V_1) - V_1 ?
1. The gas is then expanded at constant temperature until the pressure returns to p_1.
2. The gas is then cooled at constant pressure until the volume has returned to V_1.
I think the first step isn't mentioned.
thanks for point that out! i fixed it! now its a three step cycle.
But i still don't know how to figure this problem out!
please help anyone! pleaseeeeeeeeee!
47K
