Antiderivative of x^2sin(x^2) with Given Initial Condition
  • Thread starter Thread starter Xcron
    Antiderivative
Xcron
Problem states:
Find and antiderivative F of f(x)=x^2\sin(x^2) such that F(1)=0.
I thought at first that I would use u=x^2 to simplify the matter but I don't seem to get anywhere. I can't seem to figure out a way to start it off either...I was considering the Squeeze Theorem because they are functions, essentially.
Any advice/help?
Xcron said:
Problem states:
Any advice/help?
How do you use the squeeze theorem to find an antiderivative? Try integration by parts. If you haven't learned integration by parts yet, then are you sure it isn't x\sin(x^2)
Nope...sorry, I haven't learned integration by parts yet...that will be covered in the second Calculus class that I will be taking in this Winter session at my college.
And yes, I am sure it isn't x\sin(x^2)...that would be a completely superficial problem that I should not have any problems with =P.
I was thinking about this problem some more (been stuck on it since last night and it's almost the night of the next day haha) and I thought that I could possibly get an antiderivative that had \frac{1}{2} in it but then I realized that no matter what I came up with...the product rule would ruin my plan. If only that x^2 was a constant haha...
About an hour ago, I thought about a method that I could use by adding in a few functions that wouldn't change the value of f(x) and then I came up with a plan all of a sudden and it seemed to work in my head. I worked it over a few times in my head and realized that it may be the answer...I would have to use the law that states \sin^2(x)+\cos^2(x)=1.
Sadly, that didn't produce the answer either because I ended up with:
x^2\sin(x^2)=x^2\sin(x^2)(\sin^2(x^2)+\cos^2(x^2))=<br /> x^2\sin^3(x^2)+x^2\sin(x^2)\cos^2(x^2)
This didn't get me anywhere because the product rule caught me none the less...the x^2 was the problem in that case.
While typing all of this up, I decided to look in the back of the book to see what the answer is so that I could get some insight as to how to go about this problem...and I was a bit dumbfounded upon seeing it...I guess I forgot that an antiderivative can just be the general notation of an integral and the integrand...you don't necessarily need the actual antiderivative function...*sigh*...mmmm the answer was like this:
F(x)=\int_{1}^{x}t^2\sin(t^2)dt
That happened to me in a differential equations course once- I reduced the problem to an integral and spent hours trying to do the integral. The answer in the back of the book gave the solution in terms of the integral!:rolleyes:
This is probably a properties of definite integrals question, cause there is no way you can integrate this that I know of without using IBP.
\int x^{2}\sin x^{2}dx= -\frac{1}{2}\left( \cos x^{2}\right) x+\frac{1}{4}\sqrt{2}\sqrt{\pi }\func{FresnelC}\left( \frac{\sqrt{2}}{\sqrt{\pi }}x\right) + C
Well, set x=1 in the RHS and equal it to 0.
Daniel.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
