ANYS Static Structural, How to simulate 'ground ?
To simulate a fixed support in only one direction in ANSYS Static Structural, the user seeks to model a scenario where a frame can deflect upward while being constrained from penetrating the ground. A suggested approach involves fixing one edge of the frame and applying an upward force on the opposite edge. For a one-dimensional problem, fixing one node and applying force to another node is recommended. This method effectively represents the ground as a constraint while allowing for upward deflection. Proper setup of boundary conditions is crucial for accurate simulation results.
LiquidTurbo
ANYS Static Structural, How to simulate 'ground"?
Hello all, first post.
I'm having trouble simulating a fixed support in only ONE direction.
For example, imagine a gigantic frame laid on the ground and you wanted to see the forces deflect from pulling up on one corner, (the ground acts as a constraint)
ie. I'm trying to fix something in that it can't go through the ground, but is able to deflect upward.
Any help/advice would be greatly appreciated!
I would start by making one of the edge fixed and then applying force on the other edge as required. If this is a 1D problem, i would make one of the nodes fixed and applying force to the other node.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
