Application of Gauss's Law to Charged Insulators
The discussion revolves around the application of Gauss's Law to a cylindrical shell with a uniform charge distribution. The problem involves calculating the net charge on the shell and the electric field at a specific radial distance from its axis.
  • Participants discuss the application of Gauss's Law, particularly questioning the use of charge density and the relationship between flux and electric field. There is an exploration of why a specific approach may not yield the expected results.
The conversation indicates that some participants are grappling with discrepancies between their calculations and the provided solutions. One participant acknowledges an error in their calculations related to a constant, suggesting that guidance has been offered without reaching a consensus on the correct approach.
There is mention of using average area charge density and confusion regarding the appropriate use of constants in calculations, which may reflect constraints in the problem setup or assumptions made by participants.
EngineerHead
A cylindrical shell of radius 7.00 cm and length 240 cm has its charge uniformly distributed on its curved surface. The magnitude of the electric field at a point 19.0 cm ra- dially outward from its axis (measured from the midpoint of the shell) is 36.0 kN/C. Use approximate relationships to find (a) the net charge on the shell and (b) the electric field at a point 4.00 cm from the axis, measured radially outward from the midpoint of the shell.
Could someone please explain to me why this does not work:
Flux = Q/e = E*2pi*r*l
Where I am thinking of Q in terms of an average AREA charge density * the area, and not a line density * a length.
-- Is it because it lacks enough independent equations?
Why do you think that doesn't work?
Because I am currently getting a different answer than that given by the book - which is:
+913 nC
Okay it works... I've been using an incorrect value for e when solving from k - apologies.
  • · Replies 22 ·
  • · Replies 26 ·
