Approximate mass of special alloys in a nuclear reactor?
The discussion focuses on estimating the total mass of various materials in a typical Gen III or III+ PWR, specifically in the context of the entire plant. Key materials mentioned include zirconium alloy for fuel cladding, Ag-In-Cd alloy for control rods, and gadolinium as a burnable neutron absorber, primarily located in the reactor core. For the AP1000 reactor, the mass of the cladding is approximately 19,550 kg, with additional components like Ni-Cr-Fe alloy grids and stainless steel used in various systems. The conversation highlights that there is no standard mass for a Gen III+ reactor, as designs vary significantly. Overall, detailed specifications can be found in the reactor's design certification documents.
uraninite
Approximately, what is the total mass of these materials that is contained in a "typical" Gen III or III+ PWR (e.g., EPR, AP1000...)?
1/ Zr alloy (fuel cladding and other assembly components)?
2/ Ag-In-Cd alloy (control rods)?
3/ Gd (burnable neutron absorber)?
4/ Ni-based alloys?
5/ Stainless steel?
As this is quite a complicated question, please don't hesitate to only answer some parts of it. Thank you!
In the whole plant? All primary systems? The reactor vessel? Or just the fuel assemblies?
My question is about the whole plant. However I would just need an order of magnitude and I guess that 1/ Zr alloy, 2/ Ag-In-Cd alloy and 3/ Gd are mainly contained in the core.
One can find some numbers in the suppliers DCD for each reactor.
AP1000 - http://www.nrc.gov/reactors/new-reactors/design-cert/ap1000/dcd/Tier 2/Chapter 4/4-1_r14.pdf
The mass of cladding (ZIRLO) is 43,105 lb = 19,550 kg. Westinghouse fuel does not necessarily uses Gd as a burnable absorber, but rather ZrB2 coated on the fuel pellets. The fuel assembly has 10 structural spacer grids, including top and bottom (2) Ni-Cr-Fe Alloy 718 grids and 8 ZIRLO grids, and 4 intermediate (smaller) ZIRLO mid-span mixing grids.
The unit uses 53 RCCAs and 16 GRCAs. One can estimate the AIG and SS by the length of the fingers/rodlets. I believe other sections of Chapter 4 describe some of the ex-core systems, e.g., control rod drive mechanism.
There really is no typical Gen III+ reactor.
Other chapters probably have the masses of Inconel (typ 690) in the steam generators and stainless steel in piping. Stainless steel is typically 304/304L or 316/316L.
Likes uraninite
Thank you for these information.
Hello everyone, I am currently working on a burnup calculation for a fuel assembly with repeated geometric structures using MCNP6. I have defined two materials (Material 1 and Material 2) which are actually the same material but located in different positions. However, after running the calculation with the BURN card, I am encountering an issue where all burnup information(power fraction(Initial input is 1,but output file is 0), burnup, mass, etc.) for Material 2 is zero, while Material 1...
