Approximate the voltage with Kirchoff's law
Ryuuken
Kirchoff's first law gives the relationship E(t) = L * (di/dt) + R*i where L is the inductance, R is the resistance and i is the current.
<br /> \begin{tabular}{|c|c|c|c|c|c|}<br /> \hline<br /> $\emph{t}$ &amp; 1.00 &amp; 1.01 &amp; 1.02 &amp; 1.03 &amp; 1.04\\<br /> \hline<br /> $\emph{i}$ &amp; 3.10 &amp; 3.12 &amp; 3.14 &amp; 3.18 &amp; 3.24\\<br /> \hline<br /> \end{tabular}<br />
Suppose t is measured in seconds, i is in amperes, the inductance L is a constant 0.98 henries and R is 0.142 ohms. Approximate the voltage E(t) when t = 1.00, 1.01, 1.02, 1.03, 1.04.
Three-point formula: \frac{1}{2h}[f(x_{0}+h) - f(x_{1}-h)]
The official solution is:
<br /> \begin{tabular}{|c|c|c|c|c|c|}<br /> \hline<br /> $\emph{t}$ &amp; 1.00 &amp; 1.01 &amp; 1.02 &amp; 1.03 &amp; 1.04\\<br /> \hline<br /> $\emph{E(t)}$ &amp; 2.400 &amp; 2.403 &amp; 3.386 &amp; 5.352 &amp; 7.320\\<br /> \hline<br /> \end{tabular}<br />
Using 0.98*di/dt+0.142*i and di/dt = (y_{1} - y_{0})/(x_{1} - x_{0})
di/dt = 2, i = 3.10 I get 2.400.
di/dt = (2 + 2) / 2, i = 3.12 I get 2.403.
di/dt = (2 + 4) / 2, i = 3.14 I get 3.386.
di/dt = (4 + 6) / 2, i = 3.18 I get 5.352.
Now the last one is di/dt = 7 but how do I get that 7? For the other ones, I took the slope from both sides and divided by 2. The only way I can think of is to add all the previous slopes together and divide by 2, (2 + 2 + 4 + 6) / 2 = 7 but I'm not sure if that makes sense or why that would work.
Also, is there a way get some expression in terms of t for di/dt. So I can use a three-point formula like \frac{1}{2h}[f(x_{0}+h) - f(x_{1}-h)]. Substitute f(x) for E(t) to get \frac{1}{2h}[E(t_{0}+h) - E(t_{1}-h)].
Thanks.
Why do you give the "three point formula" when the problem says "using di/dt = (y_1-y_0)/(x_1- x_0)"?
Well my book says the results were given by the three-point formula (or some n-point formula) so I'm trying to figure out how to apply it to get the same result although using di/dt = (y_1-y_0)/(x_1- x_0) works.
Do you know if the way I got di/dt = 7 is correct? If so, why?
Thanks.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
