Angelos
- 17
[SOLVED] Approximation to simple harmonic motion.
A small mass m, which carries a charge q, is constrained to move vertically inside a narrow, frictionless cylinder. At the bottom of the cylinder is a point mass of charge Q having the same sign as q. Show that if the mass m is displaced by a small amount from its equilibrium position and released, it will exhibit simple harmonic motion with angular frequency
\omega = \sqrt{\frac{2g}{y_0}}
where y_0 is the height, when the mass is in equilibrium.
Simple harmonic motion:
F=-kx
Coulomb's Law(one dimension, same sign of charges):
F= \frac{kq_1q_2}{y^2}
Newton's Second Law:
F=ma
Force acting on the mass m at a height y is:
F=\frac{kqQ}{y^2} - mg
I found the potential energy by:
U=-\int F dy= \frac{kqQ}{y} + mgy
I found the equilibrium point:
mg = \frac{kqQ}{y_0^2}
y_0 = \sqrt{\frac{kqQ}{mg}}
Near (stable) equilibrium I can approximate the potential energy by some parabola with equation:
U_n = U(y_0) + B(y - y_0)^2 = 2\sqrt{kqQmg} + B(y - \sqrt{\frac{kQq}{mg}})^2
where B is some (positive) constant.
Than I can find the approximate force by taking the negative derivative of U_n. That is
F = -2B(y - y_0)
That is the same as simple harmonic motion and so we can say that
\omega = \sqrt{\frac{2B}{m}}
Well my problem is that I have no idea how to find the B or how to show that the B = \frac{mg}{y_0}. The thing is I don't know how to mathematically describe that I want the parabola of the approximate potential energy function to be the most similar to the original function near equilibrium.
I will really appreciate any help from you.
Thanks.
F=-kx
F=ma
F = -2B(y - y_0)
Thanks.
