Are temperature and pressure related by relativity?
Gerald Kaiser
Since the temperature of a gas is related to its average molecular energy and the pressure to the average molecular momentum, it would seem that a Lorentz transformation would somehow relate the two. Does anyone know of related work?
The temperature and pressure of a fluid is related to those properties in the fluid's rest frame. The temperature and pressure are related via an equation of state such as the ideal gas law. Lorentz transformations mix pressure and energy density with the off diagonal components of the energy-momentum tensor (of which kinetic energy of course gives a contribution to the energy density).
Likes Gerald Kaiser
Thanks. I should have added that I meant the LOCAL temperature and pressure in a fluid that's not necessarily in (global) equilibrium. Would those be computed in the local rest frame? I understand the the relativistic character of temperature has been a controversial topic. Has some consensus developed around it?
OK, I figured it out. Due to its isotropy, p depends only on the average of v^2 and is, in fact, proportional to the average energy. The expression for the temperature in terms of the average energy is not derived independently but uses the equation of state to show that it, too is proportional to the average energy (at least for an ideal gas). So I was wrong to think Lorentz transformations would relate the two. Thanks for the help.
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
