Area of a triangle by vectors - getting different answers
thomas49th
A = (7,6,8)
B = (2,3,-1)
C = (2, -7, 9)
Find the area of the triangle these 3 points make
I'm getting slightly different results for different combinations I use
if I take
CA = a - c = (5 , 13 , -1)
CB = b - c = (0, 10, -10)
Taking another combination
AB = b - a = (-5, -3, -9)
AC = c - a = (-5, -13, 1)
Taking the modulus of the cross product and halving yields similar, but different answers. I've check and redone my work
Why?
Thanks
Thomas
You computed AB wrong, it should be (-5,-3,-9) (added changed 3 to -3 in second coordinate). Then you get the same area.
sorry that was a typo, not actually what I did :blushing: (i've edited it now)
When I did it the first combination I get 5 sqrt(246)
But when I did the second combination I got 5sqrt(233)
Do you concur?
Thanks
Thomas
No.
I get the cross product as: (-120,50,50) with both your combinations which gives us an area of 5sqrt(194)
The correct answer is [-120, 50, 50] for your cross products.
You are screwing up when you are doing your calculations (I'm assuming you are using a CAS to input the numbers and not doing it all on paper which is why you missed it.)
If you type in for CB = <0, +10, +10> and do the cross product of CA x CB you will end up with [140, -50, 50] which results in your 5\sqrt{246}.
However if you type in CB correctly = <0, +10, -10> you'll come up with the correct answer.
Do it all on paper, ignore the calculator or CAS and you'll see where you went wrong. Once done properly you'll see that AB x AC = CA x CB
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
