Area of a vertically sliced circle
  • Thread starter Thread starter bur7ama1989
    Area Circle
4 replies · 5K views · last reply
bur7ama1989
A circle of radius 7 inches is sliced vertically, parallel to the y-axis, into three pieces. Each piece has an equal area. What is the width, x-axis, of each piece?
f(x)= +/- sqrt((r^2)-(x^2)) where "r" is the radius.
My sign for the integral is $
Using the equation for a circle above I took advantage of the obvious symmetry about the x-axis to isolate the part of the circle above the x-axis relevant to the given radius.
g(x)= sqrt((7^2)-(x^2)).
My attempt was to first define the area as an integral from the origin until x=7. (I chose x=7 because of the symmetry about the y-axis.)
I(x)= 0->7 $sqrt((7^2)-(x^2))dx
Here is where I hit a wall. The prof tried explaining to the class about Pythagoras and I thought I understood but apparently I didn't. Any assistance or pushes in the right direction would be greatly appreciated.
First the area of the circle is [itex]\pi(7^2)= 49\pi[/itex]. If it is divided into 3 pieces of equal area, each piece must have area [itex]49\pi/3[/itex].
Taking X to be the x coordinate of the left most slice, its area is given by
[tex]2\int_{-7}^X \sqrt{49- x^2} dx[/tex]
and that must be equal to [itex]49\pi/3[/itex] .
Go ahead and do the integral (the substitution [itex]u= 7sin(t)[/itex] will work), set it equal to [itex]49\pi/3[/itex], and solve for X. The symmetry tells you that the other slice is at 7+ X.
Do you even need calculus? If you consider just the part that is above the y-axis, then each slice has to be equal to [itex]49\pi/6[/itex]. and, the two end pieces are quarter ellipses.
so, if b is the x coordinate of the right slice, then
49pi/6 = (pi/4)(7-b)(49-b^2)^(1/2)
I do need to use calculus. I need to use trigonometric substitutions and integration. The method provided by HallsofIvy is the one i must use.
I followed through with the integral but now I am stuck at trying to solve for X.
What I have is:
sin^-1(x/7)+sin(2(sin^-1(x/7))) = pi/6
How do i break this down?
No, a cap of a circle is a sector minus a triangle, and you can easily find the area of each. :wink:
