Kreizhn
- 714
- 1
Consider an asteroid with an iron core \rho_m = 8000 kg\; m^{-3} covered by a thin silicate mantle \rho_m = 3500 kg\; m^{-3} with a thickness of 20% the raidus R of the asteroid.
Assume that the internal temp is T_i = 600K and is constant throughout the core due to high thermal conductivity of iron. Take the thermal energy in the core to be 3k T_i per atom and assume that the thermal conductivity is k_c = 2 W\; m^{-1} K^{-1}. Ignore the heat capacity of of the mantle. If the surface has a temp of T_s = 200K, find the value of R for which the cooling rate is about 1 K per million years
\frac{dQ}{dt} = -k_c A \frac{dT}{dx}
A is the surface area
There's a few things that are confusing me right off the bat. What is the k is the thermal energy of the core 3k T_i? There is no reference to it in any of the literature, so I find it rather ambiguous which doesn't help my situation.
I started by saying that \frac{dT}{dx} = \frac{ T_i - T_s}{0.8 R} in an approximating sense, using that the iron core is 80% of the asteroid. Then I assumed a spherical asteroid and subbed this into the above equation to get
\frac{dQ}{dt} = 5 \pi R k_c (T_i - T_s)
Now I'm kinda stuck. I want to say something about the heat production like
\frac{dQ}{dt} = ML where M is the mass and L is the energy production, however I'm not sure how to find energy production (something to do with the 3k T_i?). And then where does the 1K per million years come in?
