How Do Astronauts Measure Mass and Speed Using a Spring in Space?
  • Thread starter Thread starter bobbarkernar
    Spring
Astronauts measure their mass in space using a spring system, as traditional scales are ineffective in microgravity. The spring constant is given as 240, leading to a calculated mass of 54.7 kg for the astronaut. To find the astronaut's speed when the spring's length is 1.2 meters, the discussion suggests treating the system as a simple harmonic oscillator. The position function x(t) is proposed as x(t)=Acos(wt+phase constant), where A and w can be derived from the provided plot. Additionally, energy conservation principles can be applied to calculate kinetic energy at the specified spring length.
bobbarkernar
Astronauts in space cannot weigh themselves by standing on a bathroom scale. Instead, they determine their mass by oscillating on a large spring. Suppose an astronaut attaches one end of a large spring to her belt and the other end to a hook on the wall of the space capsule. A fellow astronaut then pulls her away from the wall and releases her. The spring's length as a function of time is shown in the figure .
What is her mass if the spring constant is 240 ?
What is her speed when the spring's length is 1.2 ?
image is http://session.masteringphysics.com/problemAsset/1001073/9/knight_Figure_14_36.jpg
i got that the answer to the first question is 54.7kg
i just don't know how to find her velocity at that length
if someone can please help me
Treating the astronaut on the spring as a simple harmonic oscillator, and using the plot, can you write down the equation that represents the position (x) of the astroanut as a function of time (t) ?
I would look at the natural frequency of the vibrations. This gives you the 'signature' of the system.
goku do u mean x(t)=Acos(wt+phase constant)?
Yes, what are the values of A and w (look at the plot)? From x(t), can you find dx/dt?
If you haven't had calculus as yet, think about energy conservation. You can find the total energy (E) using the spring constant (k) and the maximum stretch (amplitude, A). Then at x=1.2m you can plug in the value of the PE and use the value of E to find the KE at this point.
