What do the I's stand for in attenuation and power loss equations?
In the context of attenuation and power loss equations, "I1" typically represents the input power, while "I2" denotes the output power. The formula attenuation = 10 log (I1/I2) is used to calculate the loss in signal strength as it travels through a medium. Confusion arises because some examples may present the terms differently, but the standard convention is to consider I1 as the initial power and I2 as the final power. Understanding this distinction is crucial for accurate calculations in telecommunications and signal processing. Clarifying these definitions ensures proper application of the logarithmic equations in practical scenarios.
calculator20
I'm revising attenuation and power loss logarithmic equations.
The exam formula I'm given is attenuation = 10 log (I1/I2)
I'm trying to confirm what each I stands for.
Some of the examples I'm looking at seen to give input/output power, some seem to reverse it. Which is right? What do they stand for?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
13K
