Average Effective Dipole moment
The discussion focuses on calculating the average effective dipole moment of water molecules under an electric field of E = x [V/m]. Given the relative permittivity of water as 81, the dipole polarization per unit volume (P) is derived using the equation P = ε₀ * X * E, where X is the electric susceptibility. The average effective dipole moment calculated is 2.119e-38 [C*m]. Additionally, the displacement angle of the dipoles in the electric field is determined to be zero, as the field aligns with the dipoles along the x-axis.
  • Understanding of electric fields and dipole moments
  • Familiarity with the concept of relative permittivity
  • Knowledge of the equations for dipole polarization (P) and electric susceptibility (X)
  • Basic principles of molecular orientation in electric fields
  • Study the derivation of electric susceptibility in dielectric materials
  • Learn about the relationship between dipole moment and molecular structure
  • Explore the effects of varying electric fields on dipole alignment
  • Investigate the applications of dipole moments in materials science
Students and professionals in physics, particularly those focusing on electromagnetism, materials science, and molecular chemistry, will benefit from this discussion.
xz4chx
Water relative permitivity is about 81. If the electric field E=x[V/m] (x unit vector) is inside the water, what is the vector P(dipole polarization per unit volume)?
Then
Assume that the density of water is 1000 [kg/m3]
and that there are 3.34 × 1025 molecules per kg of water. (One mole of water weighs 18.0[g] since atomic weight of water is 18.0. A mole contains a number of molecules that is equal to Avogadro number (6.02 × 10^23)).
Determine an average effective dipole moment of each water molecule when E= x [V/m].(x is unit vector)
Note: each molecule of water has dipole moment. The average dipole moment,
however, is zero since these dipole moments are randomly oriented. The average effectivedipole moment px is induced by the applied electric filed because the molecules are preferentially oreinted along the field.
X = eps - 1 and P=eps0*X*E
P=Nv(p) or P=1/ΔVƩ(p)
X=81-1 = 80
And so P=eps080x
From that I would plug into the other equation correct, but i am not sure what to do once i have that plugged in for P and what to plug into for the rest
So I found out the average dipole moment by doing
80eph0/(Density of water)(# molecules of water) and got 2.119e-38 [C*m]
Now it ask for the displacement angle (the angle between the x-axis and the angle of the each dipole inside the water) when the E field is 1.0x. Since the E field is in the x direction only would the displacement angle be zero since the E field runs along the x axis
I need to be able to prove this if this is true and i don't really have any formula for finding a displacement angle. I assume it has something to do with using trig but I am not 100%
P=ε080 x
Average dipole moment is 2.119e-38 [C*m]
E = 1.0 x
And I am assuming the values are correct.
  • · Replies 25 ·
14K
