Average Resistance Force Question
To find the average resistance force exerted by the sand on a 5.2 g ball bearing fired downward, the discussion highlights two approaches: constant acceleration equations and conservation of energy. Using constant acceleration, the velocity at impact can be calculated, allowing for the determination of acceleration and subsequently the force using F = ma. Alternatively, the conservation of energy approach involves setting up an equation that accounts for initial and final kinetic energy, gravitational potential energy, and work done by the resistance force. The final answer for the average resistance force is -6.81 N, indicating the force opposes the motion of the ball bearing. Both methods provide a pathway to solve the problem effectively.
alexandray77
Our question to solve is:
A 5.2 g Ball bearing is fired vertically downward from 18m with an initial speed of 14 m/s. It buries itself a depth of 21 cm in the sand. What average resistance force does the sand exert on the ball bearing?
We know the answer is -6.81N but we are having a hard time figuring out which equations to use to solve the problem. Please help! Thanks!
You can use either constant acceleration formulae or conservation of energy to solve this problem.
With constant acceleration you are going to want to calculate the velocity of the ball at the instant it hits the ground. You will then have initial and final velocity and displacement. You can solve for a, and use F = ma to solve for F.With energy, you can use: \frac{1}{2}mv_1^2 + mg\Delta h_1 + F_1\Delta d_1 = \frac{1}{2}mv_2^2 + mg\Delta h_1 + F_2\Delta d_2
some of these terms will be zero, you are solving for F2
thank you!
