Can the Average Velocity Equation be Simplified Further?
In summary, the conversation discusses the calculation of average velocity using a given function and interval. After some corrections and simplifications, the final expression for average velocity is [E (t2+t1) + F] / (t2-t1). The conversation also touches on finding instantaneous velocity by taking the derivative of the function.
noname1
134
I need to calculate the average velocity of
d= Et²+Ft+G over the interval [t1;t2]
I after resolving i get to this function
avg v = (E(t2)² + Ft2 - E(t1)² + Ft1) / (t2-t1)
my question is it possible to go any further than this?
Your average velocity has an error. The Ft1 term in the numerator should be -Ft1. After you fix that, you can simplify your expression.
avg v = (E(t2)² + Ft2 - E(t1)² - Ft1) / (t2-t1)
= [E(t22 - t12) +F(t2 - t1)]/(t2 - t1)
Now factor (t2 - t1) out of each term in the numerator, and you can cancel with the same factor in the denominator.
yea i for got to distribute the - sign
would this be it?
[t2 - t1 (E(t2-t1) + F)]/ t2 - t1 and than the solution would be
(E(t2-t1) + F)
correct?
than like this
[E (t2-t1)(t2+t1) + F (t2-t1)] / t2-t1 =
than i can cancel the top (t2-t1) with the bottom giving
E (t2-t1) + F
No again.
Also, you should write your expression this way: [E (t2-t1)(t2+t1) + F (t2-t1)] / (t2-t1)
crossed out the wrong one, i meant
[E (t2+t1) + F] correct?
and than for instantaneous i would take the derivative which is
2et² + f correct?
Yes, but I would use the same letters as in the original problem.
v = 2Et2 + F
thanks for your help, now just have to figure out my other thread
1. What is average velocity?
Average velocity is a measure of how fast an object moves in a specific direction over a certain period of time. It is calculated by dividing the displacement of the object by the time it took to travel that distance.
2. How is average velocity different from average speed?
Average velocity takes into account the direction of motion, while average speed only considers the magnitude of motion. Average velocity is a vector quantity, while average speed is a scalar quantity.
3. What are the units of measurement for average velocity?
The units of measurement for average velocity are distance over time, such as meters per second (m/s) or kilometers per hour (km/h).
4. Can average velocity be negative?
Yes, average velocity can be negative. This indicates that the object is moving in the opposite direction of the positive direction that was defined. For example, if the positive direction is to the right, a negative average velocity would mean that the object is moving to the left.
5. How is average velocity represented graphically?
Average velocity is represented by the slope of a line on a position vs. time graph. The steeper the slope, the greater the average velocity. A horizontal line would represent an average velocity of 0, indicating that the object is not moving.
