Balancing Chemical Reactions: Isobutyric Acid + 2-Methoxyethanol
The discussion centers on the reaction between isobutyric acid and 2-methoxyethanol, resulting in the formation of 2-methoxyethyl-2-methylpropanoate. Participants identify water as a by-product, formed from the -OH group of the acid and an H atom from the alcohol. The conversation highlights the need for conditions to favor the reaction's equilibrium, suggesting that an acid catalyst (H+) can facilitate the esterification process. The reaction is described as an acid-catalyzed dehydration of an alcohol, emphasizing the importance of adjusting conditions to optimize product yield.
jin.cao
hi
i have the following reaction
isobutyric acid + 2-methoxyethanol <-> 2-methoxyethyl-2-methylpropanoate
but i don't know all of the by-products.
please help thanks
edit: i think is only water and some unreacted reactants?
Chemistry news on Phys.org
Acid is RCOOH and the alcohol is R'OH. Yes water will be a by-product. But how do you get water from this? (The -OH from the acid and the H from the alcohol bond together to form the water) What you are left with will form the other product.(btw were there any conditions for this reaction?)
no, because i am suppose to make procedure to create the product
so i will have to change the condition to shift equilibrium to the right side i guess...
why?
Because an acid and alcohol react to give ester and water in the presence of H+ as a catalyst.
thanks for confirm, rock
Just to name what your doing (basically acid catyzed dehydration of an alcohol is what your doing).
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
