Balancing magnetic forces on rods
  • Thread starter Thread starter Will Freedic
    Forces Magnetic
To balance the magnetic forces on two parallel rods carrying currents in opposite directions, the mass of the upper rod must counteract the magnetic force exerted by the lower rod. The magnetic force can be calculated using the formula F=ILxB, where B represents the magnetic field strength. To determine the magnetic field strength, Biot-Savart's law or Ampere's law should be referenced. It is recommended to consult a textbook for detailed explanations on the forces between long parallel current-carrying wires. Understanding these principles is crucial for solving the problem effectively.
Will Freedic
If two parallel rods are placed 1mm apart, with one directly above the other, each carrying a current I in opposite directions, of length L what is the mass of the upper rod as to balance the force
F=ILxB[/B]
I have little idea of how to go about attempting this solution, thankyou! [/B]
You need to assume the lower wire is held in a fixed position. It exerts a magnetic force ##IL\times B## on the upper wire.
Thankyou, but how do you work the magnetic field strength?
Biot-Savart's law or Ampere's law will be useful here.
I suggest you look in a textbook. There should be a section on force between long parallel current-carrying wires.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
