Ball on a string with initial velocity
A ball with a mass of 1.72 kg is attached to a peg with a 1.54 m string and released from a vertical position with an initial speed of 4.81 m/s. The problem involves calculating the ball's speed when the string makes a 21.7° angle above the positive X-axis using energy conservation principles. The initial attempts to solve the equation contained errors, particularly in the use of sine and the absence of a necessary factor of 2. After correcting these mistakes, the final calculation yielded a speed of approximately 6.49 m/s, which is the correct answer. The discussion highlights the importance of careful attention to detail in physics calculations.
joe_coolish
A ball with mass m = 1.72 kg is attached to a peg at the origin using a length of massless string of L = 1.54 m. It is released from the top of a vertical circle with speed v0 = 4.81 m/s. What is the ball’s speed (m/s) when the string makes an angle θ = 21.7° above the positive X axis?
Kf+Uf = Ki+Ui
K=0.5mv^2
U=mgy
I started by using Kf+Uf = Ki+Ui => .5mVi^2 + lmg = .5mVf^2 + lsinθmg
and then I solved for Vf:
Vf=SQRT(Vi^2 + lg - lsinθg)
that came out to be 5.71, but the correct answer is 6.49. Any help would be wonderful!
joe_coolish said:
I started by using Kf+Uf = Ki+Ui => .5mVi^2 + lmg = .5mVf^2 + lcosθmg
Hi joe_coolish, welcome to PF! :smile:
You've used the cosine, while you should have used the sine.
Thank you for your reply and for the welcome!
I changed the formula to Vf=SQRT(Vi^2 + lg(1 - sinθ))
which gave me this: SQRT(4.81^2+(1.54*9.8)*(1-SIN(RADIANS(21.7)))) = 5.713832509
(I like to use EXCEL for these things)
Which was my original answer. Sorry, I must have copied it down wrong :) I'll edit my original post.
But still, that is the wrong answer... Am I missing something?
In your original equation you have a factor 0.5.
In your final equation there should be a corresponding factor 2 somewhere...
(And yes, Excel is the perfect tool for things like this. :smile:)
Ah! I need to lay off the late nighters...
Thank you!
SQRT(4.81^2+(2*1.54*9.8)*(1-(SIN(RADIANS(21.7))))) = 6.493047349
It's always that dang 2!
Thank you!
Yep! :smile:
Uhh, sometimes it's a dang minus sign! :)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
