Pendulum made with a Ball and two light strings
The discussion revolves around the analysis of a pendulum system involving a ball and two light strings, focusing on the angle β. Participants express confusion over the notation and equations presented, particularly the terms "mgandS" and the forces G, F, S, and x. It is suggested to draw Free Body Diagrams (FBDs) for clarity, with emphasis on balancing forces in different positions of the pendulum. A potential typo in the problem statement is noted, which may affect the interpretation of the tension ratios in the system. Overall, the conversation highlights the importance of clear definitions and accurate representations in solving physics problems.
Aristarchus_
A ball is held at rest in position A by two light strings. We cut the horizontal cord so that the ball
begins to commute. Position B is the ball's greatest expanse on the opposite side of A
What is the ratio of the cord tension to the pendulum cord in position A before we cut the horizontal string, and the string pull in B?
The correct answer is ##1/cos^2##
$$Gx=F=tan⋅mg$$ and $$S=mg/cos$$
##1/cos^2##
Sketch
cos of what angle? β?
"mgandS" does not make sense to me
Yes, cos of beta. LaTex does not seem to work, and this was just my desperate attempt. It is not necessarily correct
For in-line LaTeX, use a double-# delimiter instead of single-$
I've fixed that part of your OP. :smile:
I'd recommend drawing the 2 Free Body Diagrams (FBDs), one for the ball in each of the two positions. Then the solution should be pretty straightforward... :smile:
What are G, F, S and x? Or is that Gx?
And how did you obtain these equations?
Likes Delta2
Me on the other hand, if ##T_H## is the tension of the horizontal cord and ##T_C## the tension of the pendulum cord, I seem to get (by balance of forces on the x-axis) that $$\frac{T_H}{T_C}=\sin\beta$$.
It is likely there is a typo in the problem statement and that it should read
"What is the ratio of the cord tension of the pendulum cord in position A before we cut the horizontal string, and the string pull in B?"
Likes Delta2
Yes if that's the case then I get same result as the given answer.
To the OP(@Aristarchus_ : You should make two FBDs for position A and B as suggested by @berkeman. In position A you should take as x and y-axis the horizontal and the vertical (gravity). In position B you should take as x-axis the tangential axis and as y-axis the radial (direction of pendulum cord) axis.
At a guess, the S in post #1 is the tension at A. If so, the OP has solved that part.
Likes Delta2
"Gx" is Gx, S is the tension force
That still doesn’t tell me what these forces are in the context of the question. How are you defining G and F, and which tension is S?
