Bank angle from horizon frame?
Artlav
How can i find out aircraft's bank angle knowing it's local frame in horizon frame?
Specifically, the horizon frame is y for up, z for north, x for east, the plane frame is x for right wing-wards, z for nose-wards, y for up. I know unit vectors of plane frame in horizon frame, and want to find out bank angle from them.
The best attempt yet is:
npr=normalize(z_horizon.x,0,z_horizon.z);
rh=normalize(y_horizon-(npr*scalar(npr,y_horizon)));
bank=sign(x_horizon.y)*atan2(sqrt(sqr(rh.x)+sqr(rh.z)),rh.y);
Basically, trying to subtract the projection of the up onto the forward from the up and compute the angle to horizon plane, but it does not work right if pitched and banked.
Any help?
Mathematics news on Phys.org
Solved it.
Project the up vector onto the plane whose normal is the nose vector, then compute the angle between the resulting reference vector and the actual up vector, correcting for sign thru wing vector.
ref=normalize((0,1,0)-(z_horizon*scalar((0,1,0),z_horizon)));
sm=scalar(ref,y_horizon);
if abs(sm)>=1 then ac=0; else ac=arccos(sm);
bank=sign(x_horizon.y)*ac;
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
