Basic Engineering design of a small lift
The discussion focuses on determining the appropriate size and thickness of square or rectangular tubing for constructing a lift to support a maximum weight of 1,000 pounds. For the horizontal member, a 63 x 63 x 4.763 mm square steel tube or a 76 x 51 x 4.763 mm rectangular steel tube are both viable options, with no significant advantage to either. For the vertical columns, a 51 x 51 x 4.763 mm square steel tube is recommended, considering a safety factor. It is noted that square tubing is preferable for horizontal support due to its resistance to flexing in certain planes. The discussion emphasizes the importance of safety factors in the design process.
badharley99
Hi,
I need a little help on figuring out what size square tubing and thickness I need to make a basic lift for taking the body of a car on and off of a frame. I have included a small drawing of what I am trying to build.
I am going to need to support a maximum of 1000 pounds. All off the force will be vertical with no side loading.
The two vertical post will be bolted to the floor and attached to the ceiling. The distance between posts will be 7 feet. The load will be lifted directly in the middle of the horizontal tube.
Can you please help with what size square (or rectangle) tubing and thickness I need for the verticals and the horizontal to support this weight? Would it be better to use rectangular tubing for the horizontal?
I understand moments of inertia, Youngs modulus have to be figured in just having a little trouble.
Thank you
Nick
badharley99@yahoo.com
So you have an applied midspan load of P = 4450 N. For the horizontal member, using a yield factor of safety of FSy = 1.70, it currently appears a 63 x 63 x 4.763 mm square steel tube, or a 76 x 51 x 4.763 mm rectangular steel tube, would work. Comparing these two options, there is no significant advantage of one versus the other. I haven't looked into the columns, so far.
Is your value for P the actual, static weight of the object to be lifted, meaning it can have a maximum mass of 454 kg? If so, can this mass be suddenly applied, or dropped, or stuck and then pop free?
Thank you for the reply on size for the horizontal.
There where be no force or acceleration, deacceleration of the load.
I appreciate all the help
thanks
nick
Using an ultimate factor of safety of FSu = 2.0, it currently appears a 51 x 51 x 4.763 mm square steel tube would work for the upright members (columns).
There are differences between square and round bars. The round ones flex more while square flexes only in some planes.
Use square for horizontal ( with the sides vertical or horizontal to ground) and round for vertical.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
