Basic physics forces problem (f=ma)
The problem involves a 28.0-kg block and a 1.00-kg bucket connected by a cord over a frictionless pulley, with static and kinetic friction coefficients provided. The key point is that static friction is overcome when the tension force equals the maximum static friction force, allowing the block to start moving. Once movement begins, kinetic friction takes over, and a minimal increase in the applied force (such as adding one grain of sand) results in acceleration. The discussion emphasizes understanding the transition from static to kinetic friction in determining the mass of sand needed to initiate movement. This analysis is crucial for solving the problem accurately.
victoration1
A 28.0-kg block is connected to an empty 1.00-kg bucket by a cord running over a frictionless pulley. The coefficient of static friction between the table and the block is 0.450 while the coefficient of kinetic friction is 0.320. Sand is gradually added to the bucket until the system just begins to move. What is the mass of the sand added to the bucket and the acceleration of the system?
F=ma
The major assumption that the problem demands---and with which I have trouble understanding---is that static friction is overcomed the moment that tension force (pulling on the block) equals the static friction force (acting in the opposite direction as tension force). There should be zero net-force at this point, and knowing Newton's first law, the block shouldn't move at all.
Does kinetic friction take over the moment that static friction equals the tension force? (thus making this problem possible)
Suppose that the applied force is exactly equal to the maximum static friction force.
How much would the applied force have to be increased so that it would produce a non-zero acceleration?
The difference between not-yet-moving and starting to move is one grain of sand. :smile:
The mass of the sand---the magnitude of the applied force---can be increased by a infinitesimally small amount to cause acceleration; thus allowing for the approximation of the mass that the question requires?
Yes.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
