How Do You Solve for Acceleration and Velocity in Basic Physics Equations?
To solve for acceleration (a) in the equation Δd = v¹Δt + ½a(t)², rearrange the equation to isolate a. This involves treating it like a standard algebraic equation while considering that the equation assumes constant acceleration. The initial velocity (v¹) represents the speed at the reference time, and Δd is the distance covered in time t. For the second question, solving for velocity (v) in the equation E = ½ m * v² requires isolating v, which can be done through algebraic manipulation. Understanding these fundamental physics equations is essential for solving problems involving motion and energy.
mrthomas
Question #1:
Δd=v¹Δt+½a(t)²
Solve for: a
Question #2:
E= ½ m * v²
Solve for: v
Δd=v¹Δt+½a(t)²
v = Δd / Δt
a = v² - v¹ / Δt
v² = v¹ + a * Δt
Δd = (v² - v¹) * Δt
Δd = v¹ * Δt + ½ a ( Δt )²
E= ½ m * v²
I'm not sure how to resolve this one.
Just solve for a in the first equation... just like normal algebra... rearrange the equation etc...
Δd=v¹Δt+½a(t)²
One needs to be consistent.
This equation assumes constant acceleration, and t would be the elapsed time from application of the acceleration. v1 would normally the initial velocity (or speed) at the reference time, and d would be the distance at time t.
See this - http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html
and
http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html
As learningphysics indicated, one can solve algebraically for the variables or coefficients in terms of variables and other coefficients.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
