Basic problem on the equation of motion
The discussion centers on calculating the braking force and time for a car coming to rest from 55 km/h over a distance of 50 m. The initial calculations yielded a braking force of approximately 3738.23 N and a time of 3.27 seconds, which contradicts the textbook answers of 1.87 kN and 6.55 seconds. Participants emphasize the importance of using consistent units, noting that kinematics equations require speeds in m/s rather than km/h. A correct formula for acceleration is provided, which is a = (v^2 - u^2) / 2s, leading to a reevaluation of the time and force calculations. The discussion concludes with a verification that the textbook's answers are indeed accurate when using the appropriate equations and conversions.
Frisky90
The brakes on a car are applied when traveling at 55km/h and it comes to rest uniformly in a distance of 50m. The mass of the car is 800 kg . Calculate the braking force and the time for the car to come to rest.
F=ma
v=u+at
t=s/v=50*3.6/55=3.27s
0=55/3.6 +a*3.27
a=-4.67 deceleration. Then F=800*4.67=3738.2263N braking force
However, according to the txtbook the right answers are: 1.87kN, 6.55s ?
F=ma
v=u+at
0=55/3.6 +a*3.27
Watch your units...your kinematics equations deal with m/s and m/s/s. You have km/h.
Also, from an energy standpoint, I verified that 1.87kN is correct for the force.
I can't find a problem with the units.I've converted km/h to m/s.
And I know that the textbook is correct :)
You have used distance traveled inappropriately. The correct way to plug in distance is
where v is final velocity, u is initial velocity, and s is distance traveled.
where v is final velocity, u is intial velocity, and s is distance traveled.
I don't understand how do you derive this expression for a? Could you explain? And if you plug in the numbers in it, you still don't get the correct answer.
Permit me to clarify. Distance traveled is the area under the line of the time - velocity graph. Since this is a straight line when acceleration is constant, the area under the line is a simple triangle, so the formula is
s = [(v + u)*t] / 2 or
t = 2s / (v + u)
for s =50, v = 0 and u = 15.273
t = 100/15.273 = 6.548 seconds.
solving for [a] we use v = u + at and get
0 = 15.273 + at
0 = 15.273 + 6.548a
6.548a = -15.273
a = -2.332
The results are the same using the expression I originally gave, albeit that one is a little harder to derive.
