SR & Lorentz Scalar Fields: Covariant Diff. & Wave Amplitude
dyn
Hi. In GR , covariant differentiation is used because the basis vectors are not constant. But , what about in SR ? If the basis vectors are not Cartesian then they are not constant. Does covariant differentiation exist in SR ? And are for example spherical polar basis vectors which are not constant treated differently to Cartesian basis vectors in SR ?
Another question I have is regarding Lorentz Scalar Fields. I have read that a wave can be treated as a Lorentz scalar field which means that its amplitude in one frame is the same as measured in any other inertial frame but why is the wave amplitude not Lorentz contracted ?
Thanks
Yes, it is needed with non-Cartesian coordinate systems. Some texts use that as a gentle way to introduce the Christoffel symbols. IIRC, Schutz does that in 'A first course in General Relativity', with a chapter introducing Christoffel symbols et al, mostly focusing on polar coordinate systems, before he introduces curvature in the following chapter.
Likes bcrowell
Just to clarify further, this is nothing particular for Minkowski space - it is the case for any set of non-affine coordinates on a regular euclidean space as well.
Likes PWiz
Thanks. So if I was working with spherical polars in Minkowski space I would use covariant differentiation as the basis vectors are not constant.
Any thoughts on my problem with wave amplitudes and Lorentz scalar fields ?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
