Bat Hitting Ball: Find Speed After Collision
  • Thread starter alfredo24pr
  • Tags
    Ball
In summary, the ball and bat collide with equal speeds of 2.30 m/s. This is an elastic collision with no rotational motion. By using the conservation of momentum and energy equations, and assuming the mass of the bat is much larger than the ball, the final velocity of the ball can be determined.
alfredo24pr
49
A ball and bat, approach one another each with the same speed of 2.30 m/s, collide. Find the speed of the ball after the collision. (Assume the mass of the bat is much much larger than the mass of the ball and that this is an elastic collision with no rotational motion).
m1v1i + m2v2i = m1v1f + m2v2f
Im stuck at beggining :/
hi alfredo24pr! :smile:
elastic collision means that you use conservation of energy also :wink:
hi tiny tim..so that means I have to relate kinetic energy?
(just got up :zzz: …)
yup! :biggrin:
what do you get? :smile:
yup! :biggrin:
umm.. I do not understand. I know that I have to relate to v used in momentum to the v in kinetic energy :confused:
write out the conservation of momentum equation and the conservation of energy equation :smile:
and
1/2mvi2 + mghi = 1/2mvf2 + mghf
ok, now use 2.30, and assume that m2/m1 is very much less than 1 :wink:
so m2 / m1 is negligible therefore I can write it out as 0?
I still do not understand how to work with both equations.
start :smile:
tiny-tim said:
start :smile:
uhh..
m1v1 = m1(2.3)
m2v2 = m2(2.3)
1/2mvi2 = 1/2m(2.3)2
and then i substitute
m1(2.3) + m2(2.3) = m1vif + m2vif
1/2mvi2 + 0 = 1/2mvf2??
what is this supposed to be? :confused:
(in particular, what is the "0" ?)
1. How does the speed of the bat affect the speed of the ball after collision?
The speed of the bat directly affects the speed of the ball after collision. This is because the bat is the object that is transferring its kinetic energy to the ball. The greater the speed of the bat, the greater the speed of the ball after collision.
2. What other factors besides speed of the bat can impact the speed of the ball after collision?
The mass of the bat and the mass of the ball can also impact the speed of the ball after collision. Additionally, the angle at which the bat strikes the ball and the elasticity of the ball can also play a role in determining the speed of the ball after collision.
3. How can we measure the speed of the ball after it is hit by a bat?
The speed of the ball after collision can be measured using a radar gun or a high-speed camera. These tools can accurately measure the speed of the ball in miles per hour (mph) or meters per second (m/s).
4. Is the speed of the ball after collision always the same as the speed of the bat?
No, the speed of the ball after collision is not always the same as the speed of the bat. This is because some of the kinetic energy from the bat is lost during the collision due to factors such as friction and air resistance.
5. Can we calculate the speed of the ball after collision using a formula?
Yes, the speed of the ball after collision can be calculated using the formula: v(ball) = (m(bat) * v(bat) + m(ball) * v(ball))/ (m(bat) + m(ball)), where v(ball) is the speed of the ball after collision, m(bat) is the mass of the bat, v(bat) is the speed of the bat, and m(ball) is the mass of the ball.
