Bathroom scale compression problem
  • Thread starter Thread starter shrtweez13
    Compression Scale
When jumping onto a bathroom scale from a height of 1.4 m, the gravitational potential energy (mgh) converts into spring potential energy (1/2 kx^2). The spring constant (k) can be calculated using Hooke's law, given the scale compresses 0.50 mm under a weight of 700 N. The total distance fallen includes both the height of the jump and the compression of the spring. While this additional compression may seem significant, it has a minimal effect on the scale reading at the peak. Understanding these energy transformations is crucial for solving the problem accurately.
shrtweez13
if you stand on a bathroom scale, the spring inside the scale compresses .50 mm, and it tells you your weight is 700 N. Now if you jump on the scale from a height of 1.4 m, what does the scale read at this peak.
i found an equation to use, i just can't figure out what I'm solving for. I'm using
mgh = 1/2kx^2
i have m (71.4) g (9.8) and h (1.4). what i don't know is k and x. can anyone help please?
mgh = 1/2kx^2
This is a statement of conservation of mechanical energy: the initial gravitational PE is transformed into spring PE.
k is the spring constant, x is the displacement of the spring from its uncompressed position. You can figure out the spring constant from Hooke's law (using the data supplied in the problem set up): F = -kx.
Yeah k can be determined from the given data.
One more thing!
When you jump from a ht. of 1.4 m, the gravitational PE lost by you is definitely stored as PE in spring. But You are not actually falling 1.4 m but you are falling 1.4 m PLUS the distance contracted bythe spring.
In this case, it wouldn't make much of a difference(why?)
Anyway, you should know the concept! :smile:
