MHB What is the bearing and distance between cities A and C?
  • Thread starter Thread starter Jerome1
    Bearing
The airplane flew from city A to city B on a bearing of 65 degrees, covering a distance of 60 km, and then from city B to city C on a bearing of S 25 degrees W for 86 km. To find the bearing of city C from city A, the Law of Cosines is applied to calculate the distance AC and angle BAC. The angle at point B is determined to be 40 degrees. By adding 65 degrees to the calculated angle BAC, the final bearing from A to C can be established. The discussion emphasizes the importance of using trigonometric laws for accurate navigation calculations.
Jerome1
An airplane flew from city A on a bearing of 65 degrees to city B, a distance of 60km away. It then flew from B on a bearing of S 25 degree west to city C at a distance of 86km. Calculate (1) the bearing of C from A (ii) The distance between A and C
Mathematics news on Phys.org
Have you drawn a diagram yet?
Hello, Jerome!
An airplane flew from A to B on a bearing of 65o for 60km.
It then flew from B to C on a bearing of S 25o W for 86km.
Calculate (1) the bearing of C from A,
. . . . . . . (2) the distance between A and C.
Code:
                  B
      :    60 * / :
      :65[SUP]o[/SUP]* 40[SUP]o[/SUP]/25[SUP]o[/SUP]:
    A *     / 86  :
          C
You know: AB = 60,\;BC = 86,\;\angle B = 40^o
Use the Law of Cosines to find side AC.
Then use the Law of Cosines to find \angle BAC.
Add 65^o to find the bearing of AC.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
