Bearing failure rating? Simple rev counter?
The discussion centers on determining the failure rating of roller bearings in a self-designed turbo jet engine. The user seeks a formula to calculate the maximum revolutions per minute (RPM) a roller bearing can handle, considering factors like ball size and bearing dimensions. It is noted that bearing data sheets provide essential information, including maximum RPM and load limits, which are crucial for assessing bearing performance and safety. The user also suggests using a strobe light to measure the RPM of the impeller, indicating a practical approach to monitoring engine speed.
  • Understanding of roller bearing mechanics
  • Familiarity with turbo jet engine design principles
  • Knowledge of bearing data sheets and specifications
  • Basic principles of rotational speed measurement techniques
  • Research "roller bearing failure ratings and calculations"
  • Learn about "using strobe lights for RPM measurement"
  • Explore "bearing data sheets and their specifications"
  • Investigate "design considerations for turbo jet engines"
This discussion is beneficial for high school students interested in mechanical engineering, hobbyists designing turbo jet engines, and anyone involved in the study of bearing mechanics and performance optimization.
agusta
Firstly I would like to point out I have absolutely no idea what I am doing and will most likely be blind or dead by tomorrow. But anyway.
I've finally finished me first turbo jet engine (from scratch I would like to add and designed myself and dodgy as I am pretty convinced that it won't explode (mainly because its about a hundred times stronger than it needs to be) but I do expect it to either disintegrate or have bearings fail. I have used roller bearings, which was a stupid idea I know but it saved me a lot of time. What I would like to know is how I can determine roughly what speed a roller bearing will fail at excluding sideways force and heat etc. I have a formula for the failure rating when a certain sized bearing is under a sideways force but I can't find one for the maximum revs they can handle.
There must be a formula where you can use the ball size, number of balls, outside diameter, inside diameter width etc.
Also I would like to have a simple way of working out the number of revs its doing. Maybe using a strobe light and adjusting the frequency until the impeller stops moving? Then you could use that frequency someway. Just a thought. (probably stupid but hay I am at high school where making a fire poker in engineering is classed as complicated)
The thing is I don’t what it disintegrating and blinding a few fellow class mate. I suppose I would get on the news if it exploded and kill a few people (I shouldn’t say that, sorry)
I know I am only at high school and you guys are all probably either 4th year mechanical engineering students or actual engineers but I hope to be a 4th year mechanical engineering student one day so give use a break)
So if you have any ideas that’d be great. Anything really.
I posted this in general engineering but i though it would be more appropriate here.
Cheers
Bearings have data sheets. The max RPM, load limits and expected failure life are quoted in said data sheets.
See my response in the General Engineeering Topic. Please don't double post.
  • · Replies 16 ·
