- 13,794
- 16,593
Ack! You're right. In order for the length to remain invariant the worldlines of the nose and tail, which are hyperbolae, must have a common focus. Which means different proper accelerations.stevendaryl said:If we're talking about a normal rocket, propelled from the rear, the proper acceleration will vary from back to front, with the acceleration being greater in the rear.
That wasn't my intention. I was pointing out that the rocket isn't unstressed, and that the two ends of the rocket don't start moving at the same time in the initial rest frame, unlike Bell's rockets. I agree that the same is true of rockets "hanging" from engines near their nose, and didn't intend to imply otherwise.stevendaryl said:It's a little bit misleading to attribute this to the fact that it is pushed from the rear.
I was also claiming that the difference between Bell's spaceships and a long rocket is just the timing of the movement starts. That was wrong, as you pointed out. They are different, but the proper accelerations are also different, contrary to what I said above.
