Bessel Function / Helmholtz equation
rustygecko
I'm interested in the solution of an equation given below. (It's not a homework/coursework question, but can be stated in a similar style, so I thought it best to post here.)
A \nabla^2 f(x)-Bf(x)+C \exp(-2x^2/D^2)=0
where A,B,C,D are constants.
I know the solution (or the solution that's relevant for me) is:
f(x)=\frac{D^2C}{4} \int_0^{\infty} \frac{kJ_0(kx)\exp(-D^2k^2/8)}{Ak^2+B}dk
where J_0 is a zeroth-order Bessel function, but I'm not entirely sure how to get there.
It seems like a starting point might be solving:
A \nabla^2 f(x)-Bf(x)=0
which looks like a Helmholtz equation and then modifying that solution, but I haven't been able to solve that so far.
Are you familiar with Green's functions?
You are dealing with a screened Poisson equation here, which can be solved by means of Green's function (which is where the Bessel function comes in). The solution also depends on the boundary conditions, which you can implicitly defined here.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
