B How can we accurately model data using curve fitting techniques?
  • B
  • Thread starter Thread starter houlahound
    Data Fit
Accurate data modeling using curve fitting techniques raises questions about the theoretical foundations behind polynomial fits. While a polynomial of degree 2 can perfectly fit the coordinates of a hanging chain, it does not provide insight into the underlying physics, which is better described by a catenary curve derived from theoretical analysis. This disconnect highlights a common issue in science where empirical data can yield precise equations without theoretical justification, as seen in examples from AI applications in physics and biology. The evolution of scientific theories, such as gravitation, demonstrates the importance of understanding key variables rather than relying solely on fitted curves. Ultimately, while polynomial fits can be useful, they may obscure deeper insights into the phenomena being studied.
houlahound
While using a piece of jewelry ie a fine chain hanging against a piece of graph paper then placing an origin, axes and scale on the paper I collected the position of the chain as a set of coordinates (x,y).
Entering the data into curve fitting software a perfect fit for a polynomial degree 2 was obtained.
Also fitted the data to a catenary made of exponentials.
My question is what does it mean to say the theoretical curve to model some data is this when you can adjust any polynomial within reason to get the same fit.
Mathematics news on Phys.org
We know that when you hang a chain you get a catenary. We also know that you can approximate a catenary within a given domain using a polynomial.
You were approaching the problem from the measurement end to get your polynomial and that's where you have to stop. You have no theory to explain the polynomial fit or why you came up with a polynomial. This happens a lot in science where the data is neatly described by a polynomial but there's no theory to explain it.
In one example, Cornell Univ folks had developed an AI that could discern the equations of motion from data about a compound pendulum and the equations were spot on. However later a biology team used the same program to analyze some cell data and once again they got a equation that was spot on but they couldn't publish because they couldn't explain the equation from theory.
In contrast, the catenary comes from analyzing the nature of the hanging chain and deriving the catenary from that analysis.
Likes houlahound
thanks, so it's not so much a case of lack of rigour it is that a fitted curve gives no insight to what the key variables are?
Here's that article I mentioned on the program that "understands" physics:
https://www.wired.com/2009/04/Newtonai/
Another example could be the evolution of the theory of gravitation from the cycles of Ptolemy to Kepler's laws to Newton's Law of Gravitation to Einstein's Theory of General Relativity. In each case, a better equation was developed to address the ever more precise collected data.
Here's Feynman's lecture on this evolution:
http://www.cornell.edu/video/richard-feynman-messenger-lecture-1-law-of-gravitation
Likes houlahound
I found this related article in Wired about how students do experiments which you may find interesting:
https://www.wired.com/2016/09/might-gotten-little-carried-away-physics-time/
In this case, the students graph their data and fit it to a quadratic which is the correct answer and perhaps this makes students want to believe that everything works the same way.
However, the world intrudes and may make things locally in your limited experiment match a polynomial okay but in a bigger sense with theory we can find a better answer...
Likes houlahound
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
