Beta - special functions - manipulation
DigitalSwitch
I have this incomplete Beta function question I need to solve using the Beta function.
\int^{a}_{0}y^{4}\sqrt{a^{2}-y^{2}}dy
Is there an obvious substitution which will help convert to a variant of Beta?
Beta function and variants are in Beta_function Wikipedia article
Every time I look at the question I just start trying to integrate it as if the Beta function is irrelevant. I can't grasp how the beta function is applied to the 'incomplete' questions.
Thanks.
How about trying the substitution y=a*sqrt(t)?
That did it thanks. Great skills! (I want them)
I've still got something wrong.
Subbing y=a\sqrt{t} into integrand:
a^{4}t^{2}\sqrt{a^{2}(1-t)}
Changing bounds and var (wrongly?):
t=\frac{y^{2}}{a^{2}}\rightarrow \frac{a^{2}}{2y}dt=dy
\frac{a^{2}}{2y}a^{5}\int^{1}_{0}t^{2}(1-t)^{1/2}dt
which gives (by subbing indices + 1 into Beta function):
\frac{a^{7}}{2y}B(3,3/2) but B(3,3/2)=\frac{16}{105}
Mathematica says the answer by integration is \frac{\pi a^{6}}{32}
Pi is missing! I have a feeling that the beta function should of produced it.
It will. You did it wrong. How can you wind up with a y outside of the integral? y is a function of t. Do it more carefully.
Solution
To solve: \int^{a}_{0}y^{4}\sqrt{a^{2}-y^{2}}dy (Utilising the Beta special function)
Use the substitution y=a\sqrt{t}
This implies t = \frac{y^{2}}{a^{2}}
Change bounds and variable
for y=0, t=0; for y=a, t = a2/a2 = 1
Changing variable, bounds and subbing for y gives equivalent integrals:
\int^{a}_{0}y^{4}\sqrt{a^{2}-y^{2}}dy \Leftrightarrow \int^{1}_{0}\frac{a^{6}t^{2}(a^{2}-a^{2}t)^{1/2}}{2a\sqrt{t}}dt
Simplifying (which gives the desired Beta function form)
\frac{a^{6}}{2}\int^{1}_{0}t^{3/2}(1-t)^{1/2}dt
Solution
\frac{a^{6}}{2} B(5/2,3/2) = \frac{a^{6}}{2}\cdot\frac{\pi}{16} = \frac{\pi a^{6}}{32}
Thanks for the help Dick. I obviously need to work more carefully and practice far more calculus as I keep making the simplest mistakes. As for choosing the substitution, I hope that comes with practice.
I hope my working will help somebody, I end up on these forums from google searches often!
That looks great. If you look back at it, the choice of y=a*sqrt(t) isn't really all that clever. It's just about the only thing you can do to get a (1-t) into the integral.
I can't not post on forum homework I want to know so fast please help me
