How Far North Did the Biker Travel in 10 Minutes with Given Velocity and Angle?
  • Thread starter physicsgurl12
  • Tags
    Angle Bike
In summary, the person on the bike traveled at a constant speed of 8.4 m/s for 10 minutes in a direction 25 degrees north of east. Using the equation for projectiles, the distance traveled was found to be approximately 5040 meters. To find the northward and eastward displacement, a triangle was drawn and the distance was broken down into its components, resulting in a northward displacement of approximately 2100 meters.
physicsgurl12
184
riding his bike with v=(8.4m/s,25 degrees north of east) for ten minutes. how far to the north of the starting position did he end up?
x=v^2sin2angle/g
70.56sin50/g
theres not even a t in this.
physicsgurl12 said:
x=v^2sin2angle/g
This equation is for projectiles.
The guy on his bike is moving at a constant speed. That makes things really easy. You have speed and time, how do you find distance? For sure, you know this. :smile:
Assuming you find this distance, it is the distance traveled in the direction of motion (which is 25 degrees north of east in this case). How, then, do you break that down into total northward displacement and total eastward displacement? Now it's just geometry. Draw a diagram of the situation, this will help immensely.
v=d/t 8.4m/s=d/600s d=5040m ? draw a traingle??
Yes, exactly. 5040 m is the distance traveled along the diagonal line that is oriented 25 degrees above the horizontal. (On a diagram where N-S is drawn to be vertical and E-W is drawn to be horizontal).
so about 2100 d?
physicsgurl12 said:
so about 2100 d?
Post what you did to arrive at that answer and why you think that is the thing to do...(remember it's whether or not you understand the concept and the methods of your solution that are important, not the final numerical answer).
okay well i was kinda confused on what goes where on the triangle
Well that still doesn't tell me what you did.
Anyway, the correct answer is just over 2100 m, so you probably did the right thing. I just wanted to make sure you understood the geometry and why that was the method of solution before confirming your answer.
okay got ya.
1. How does the angle of a bike affect its speed?
The angle of a bike does not directly affect its speed. However, the angle at which the bike is ridden can impact factors such as air resistance and stability, which can indirectly affect speed.
2. Is it better to ride a bike at a higher or lower angle?
The angle at which a bike is ridden depends on the terrain and the rider's preference. Generally, a lower angle (closer to the ground) provides better stability, while a higher angle (more upright) can improve visibility and reduce strain on the rider's back and neck.
3. How do gears affect the angle of a bike?
Gears do not directly affect the angle of a bike. However, using different gears can change the angle at which the rider sits on the bike and can impact the force and speed at which the bike moves.
4. Can the angle of a bike impact the rider's performance?
Yes, the angle of a bike can have an impact on the rider's performance. The right angle can improve the rider's comfort and stability, allowing them to ride longer and more efficiently. However, an incorrect or uncomfortable angle can lead to fatigue and reduced performance.
5. What is the ideal angle for bike riding?
There is no one ideal angle for bike riding as it depends on various factors such as the rider's comfort, the terrain, and the type of bike. It is important to find a comfortable and stable angle that works for the individual rider.
