Direction of Magnetic Field Outside a Cylindrical Wire
The discussion centers on determining the direction of the magnetic field outside a cylindrical wire carrying a steady current of 1A. The Biot-Savart law indicates that the magnetic field points in an azimuthal direction, meaning it is tangent to circles centered around the wire rather than radially outward. The radial component of the magnetic field is zero, which can be understood by applying the right-hand rule to the cross product of the current density and the radial unit vector. Clarification is provided that "azimuthal" refers to the tangential direction at a point on the circular path around the wire. Understanding these concepts is crucial for correctly applying the Biot-Savart law in this context.
Cazicami
Hi guys, sorry to bug again, but I am a wee bit stuck.
A steady current of 1A flows down an infinitely long straight cylindrical wire of radius r=5mm
Explain in what direction the magnetic field is pointing outside the wire
The Biot Savart law - B = 4∏/μ ∫∫∫ ((Jdv) x r)/r2
Sorry for the poor equation
I would have said the magnetic field would point radially around the wire.
However the solutions say: From the Biot-Savart law follows that the magnetic field has to point in azimuthal direction. The radial component is zero.
I have tried googling azimuthal as I have no idea what it means, and it seems to mean an angle away from horizontal, but if anyone could clear up what the answer is, or direct me to something that would help that would be great.
Thanks
For a point p located a distance r from the wire, imagine a circle of radius r lying in a plane perpendicular to the wire, with center at the wire, and passing through the point p. "Azimuthal" means tangent to the circle.
Thanks, but why is the field tangential to that point and not radial around the loop?
Think about the direction of the cross product ##\vec{J}\times\hat{r}## in your integral expression for the Biot-Savart law.
[Minor comment: When you wrote the integral for the Biot-Savart law, the fraction out front should be ##\frac{\mu_o}{4\pi}##]
you should use right hand thumb rule while calculating cross products.In this case you can also work with pointing your right thumb along the direction of the current then the way your fingers curl to form a fist is the direction of the field.clock wise concentric circles from top.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
