Understanding BJT Emitter Resistance: Explained by Horowitz & Hill
  • Thread starter Thread starter garibaldi
    Bjt Resistance
The discussion centers on the intrinsic emitter resistance (re) in BJTs as explained in Horowitz & Hill. Participants clarify that re represents the dynamic resistance of the base-emitter diode, typically placed in series with the emitter. However, in emitter follower circuits, it is often shown connected to ground, which helps achieve low output resistance. There is debate about the correct expression for output impedance, with suggestions that it should involve adjustments to the terms related to beta. Additionally, the importance of a pull-down resistor at the emitter output is emphasized to prevent floating voltages when no load is connected.
garibaldi
Hey everyone,
Im currently reading Horowitz & Hill and am a little confused on the topic of the intrinsic emitter resistance (re). I understand that this resistance is essentially the dynamic resistance of the base-emitter diode.
I assumed that when analyzing a circuit this resistance should always be placed in series with the emitter. However H&H seem to place this resistance from the emitter to ground in the emitter followers they demonstrate.
In the case of the emitter follower circuit this makes sense because the low re means that the circuit will have a low output resistance as expected. I just don't understand why they placed it to ground.
The circuits in question are attached.
What makes you think that the resistors from emitter to ground shown in the images are re, the intrinsic emitter resistance? They aren't labeled re.
I think you mean r'e or pronounced 'R prime E' or 'R E prime'. Summarized, R'e is the AC impedance of the base emitter junction. Normally the output imedance of an emitter follower is Re (actual resistor from emitter to ground) in parallel with [(beta*the base circuit impedance) + r'e].
You say:
"Normally the output imedance of an emitter follower is Re (actual resistor from emitter to ground) in parallel with [(beta*the base circuit impedance) + r'e]."
Shouldn't the "(beta*the base circuit impedance)" expression be something more like "(the base circuit impedance/beta)"? Actually, I think the "beta" should be "beta+1".
The Electrician said:
You say:
Yes, my bad.
It is usually a good idea to have a pull-down resistor on the emitter output to keep the output potential from floating up to the base potential when the external load is not connected. It is absolutely necessary if the external load does not have a dc path to ground.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
