BJT with non constant beta-value burned out?
  • Thread starter Thread starter nareto
    Bjt Constant
The discussion revolves around measuring the beta-value of an NPN BJT transistor using a circuit with varying base resistor values. The user observed a significant decrease in beta from 50 to 1.2 as the base resistor was changed, raising concerns about potential damage from desoldering the transistor. Responses clarified that the observed beta variations are typical, with normal fluctuations expected due to changes in collector current and collector-emitter voltage. It was emphasized that measurements taken when the transistor is saturated should be disregarded, as they do not yield reliable beta values. Overall, the beta range of 25 to 50 is considered acceptable, despite the user's expectations based on a reference table.
nareto
Hello, I have taken some measurments following a proposed experiment in a begginners electronics book to calculate the beta-value of an NPN BJT transistor. The circuit was as follows:
____________
+ R_B R_C
9V | C_|
- B
| E
|_______ _|
EDIT: of course it's not clear, at least in my browser. Basically it's a 9V battery with the + that has two branches, one that goes to the Base of the transistor and one to the Collector, each branch has in series a resistor, respectively R_B and R_C. The minus is attached to the Emitter.
hope it's clear... E B and C are the tranistors emitter, base and collector, R_C a 1kOhm resistor and R_B was a resistor whose value changed during the experiment. Also, not shown, there were two amperometers in series respectively with R_B and R_C (to measure I_B, base current, and I_C, collector current) and a voltmeter between C and E (to measure the collector-emitter voltage).
So, what *should* have happened is that, starting with R_B=1MOhm and decreasing this value (I didn't use a potentiometer but different resistors), I should have obtained increasing values of I_B and of I_C in such a way that there ratio, beta=I_C/I_B would be more or less constant.
However, I got the values that can be seen in the image:
http://i.imgur.com/y9EZZ.jpg
With R_B=1MOhm beta is 50, and then it constantly decreases till it reaches 1.2! This is strange...
So, given that I desoldered the transistor out of a previous made PCB, could I have damaged it by desoldering? Is this non-constant-beta-value a typical symptom of having burned out the transistor?
thanks for any help,
renato
In the last 3 measurements the transistor is saturated. You can't really make a sensible measurement of beta in a saturated transistor so you definitely should ignore those last three lines. (You *really* need to understand that the collector current is limited by the collector resistor and not the base current in this case).
As for the other measurements they look ok. It’s normal to have some variation in beta with both Ic and Vce. Normally I would have expected beta to increase somewhat with increasing Ic (at least up to several mA) and to decrease somewhat with decreasing Vce. Overall though, the range of variation that you got in beta (25 to 50) is not too large.
thanks for pointing that out! yeah I think I got it
Oh, ok. I thought it was large because on the book there was a sample table and beta value for them was allways 100, only one or two times 98; so I expected that kind of variancy (though they warned that they had used high precision equipment and mileage could vary)
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
