BLASIUS EQUATION Solutıon with Finite Difference Method
antiochos
1) Using a similarity variable, the boundary layer equations for a two-dimensional, incompressible flow over a flat plate can be written below:
2f'''+ff''=0
The boundary conditions are:
a) f ' (0) = 0, no slip at the wall
b) f(0)=0, solid wall
c) f ' (n) goes 1 as n goes infinity boundary layer solution merges into the inviscid solution.
I) using finite difference method, obtain a numerical solution of this equation. Plot f ' and f as a function n.
II) The shear stress on the wall requires f " (0) to be determined. From the numerical solution compute f " (0).
I ve uploaded the original doc file.
Can you help me with this?
You have stated what is clearly a homework problem but shown no work at all. I'm moving this to the "Calculus and Beyond" homework section but you will have to show what you have done yourself.
ok my path:
f'=y
y'=f''
the replaced y s with f s.
Then i wrote the finite difference equation.
Then i took the integral of y' with trapezoid rule..
i could not go any further
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
