Solving Block on Incline Physics Problem
  • Thread starter Thread starter Maiia
    Block Incline
The discussion focuses on solving a physics problem involving a block on an incline. The user presents their free body diagram (FBD) and equations but receives feedback indicating errors in the representation of forces and the use of equations. Specifically, it is pointed out that the gravitational force (Fg) should be resolved into its components without retaining the downward force in the FBD. Additionally, there is a correction regarding the order of gravitational components in the equations. The user is advised to make these adjustments to achieve the correct solution.
Maiia
Can someone tell me if I'm doing this problem right?
Here is the picture of the problem:
http://i210.photobucket.com/albums/bb23/Kyashii628/block.jpg
In my FBD, I have Fg pointing down, Fgy perpendicular to the incline and pointing down, Fgx parallel to incline pointing down the ramp (to left), kinetic friction pointing up the ramp (to right), and normal force pointing opposite from Fgy.
Fnet= -ma
fk- Fgx= -ma
u(Fn)= -ma
u(345.0615986)= 648.9664808 -240
u= 1.182397583
good, but remember in your FBD, that once you resolve Fg into its x and y components, you should 'cross out' the Fg downward force.
Fnet= -ma
fk- Fgx= -ma
good
u(Fn)= -ma
I'm sure you meant u(Fn) = fk
you have your mg(sin theta)and mg(cos theta) reversed.
u= 1.182397583
Correct your error and your result should be fine.
