Solve Block on Incline HW: F=ma & Fn=mgsinθ
  • Thread starter Thread starter PierceJ
    Block Incline
The discussion focuses on understanding the normal force and its components when analyzing a block on an incline using F=ma. Participants clarify that the normal force is not equal to mgsinθ, but rather involves using cosine to resolve the weight into components. The correct approach is to define the x-axis parallel to the incline and the y-axis perpendicular, which influences how forces are projected. It is emphasized that the angle between the weight and the normal force is θ, necessitating the use of cosine for calculations. Ultimately, the relationship between the normal force and weight requires careful consideration of geometry and trigonometry in the context of the incline.
PierceJ
http://i.minus.com/iVbsy2FomprcM.PNG
F=ma
I'm struggling with the normal force and I'm not sure if the component of the force F is the cosine or sine. I see examples where its sine but that doesn't make any sense to me. Isn't the x direction supposed to be cosine?
Fn = mgsinθ
81.2cosθ - Fnμ = 9.23
-Fnμ = -65.897
F=ma
Fn = mgsinθ
-Fnμ = -65.897
For simplicity of the solution, the x-axis is chosen to be the axis parallel to the incline, and the y-axis is the axis perpendicular to the incline. In this manner, the applied force F is already in the in the x direction, and when you draw your FBD for the forces (you are missing at least one), a bit of geometry/trig and Newton 1 in the chosen y direction will you give you the relationship between the normal force and weight. Since the applied force is already in the x direction and the normal force in the y direction, it is the weight force that needs to be broken up into its x and y components before applying Newton's Laws. And no, the x-axis is not always the cos, it depends on what angle you are working with and the trig properties of a right triangle.
Okay.
So the normal force is equal to mgsinθ?
No. If you aren't sure, then you look at a limiting case: let ##\theta## go to zero, and you know that then the normal force is equal to mg. Forces the choice between ##mg\sin\theta## and ##mg\cos\theta## to be the latter because cos(0) = 1.
The normal force is ##\perp## the incline. In your FBD you should easily see that the angle between mg and the normal force is ##\theta## and not ##{\pi\over 2}-\theta##. So cosine to project mg on the perpendicular.
Don't associate x with the one and y with the other. Sometimes it's like this, other times it is the other way.
