Plotting Bode of Resistor w/ DC Source: 20*log(0)
In summary, you are plotting the bode of a resistor connected to a DC source. There is no frequency at all being produced, so the bode magnitude plot should be 0. What should be the value for the step of 5 volts? The bode magnitude plot should start from 20*log(jw)=20*log(0), but what should be the value for the step of 5 volts? The bode magnitude plot should look like a point.
ujjval rathod
I am ploting bode of resistor connected with DC source.So no freqvancy at all! The bode magnitude plot should be(or it
should start from) 20*log(jw)=20*log(0) (jw=0 because we have dc source) what should be the value??for step of 5v... what
should bode look like??
Maybe it would look like a point. I really don't know because Bode plots are not intended for DC.
Why are you doing that?
yes true bodes are not for DC... But can you tell me what is the frequency of DC I mean 0 or Infinity?
Or suppose I have square wave of some frequency...then what would be the transfer function?? for R it would be L^-1(r)=1 or r and for input i think it should be 1/s...
also if you can tell me...this..
If we have LTI system and if we apply one frequency say 5HZ the in output will we get same frequency or we may get different
frequency?? yes amplitude and phase may change that i undestand..
The frequency of DC is zero. A square wave cane be represented as a Forier sum of many frequencies. Google Fourier series.
Likes ujjval rathod
ok i know Fourier series... So you mean we have to get Fourier series of the signal and then once we get it... we take laplace transform of that...?? So that we can analyse bode...
That is still not appropriate for Bode plots. A Bode plot shows the response of a system as a function of frequency. Continuous changes in frequency.
A Fourier series of a square wave gives you values at discrete integer multiples of the fundamental frequency. When plotted, you would have a series of isolated points, not lines.
Once you have a specific signal, it doesn't make sense to make a Bode plot of it. Perhaps you are thinking of power spectral density.
I am thinking of circuit which has only Resistance and a supply...so Laplace of resistance of 1ohm is always 1 so we only need to take laplace of input to analyse a bode...
hey i am stuck with the question of bode of circuit having resistance connected to sinusoidal source...
What i am trying to get is bode of that circuit... so I take laplace of sin=1/(s^2+1)... Now this is our T.f. If i put diffrent values of frequency do i get the bode magnitude plot??
If your circuit has an input location and an output location, then it has a Bode plot. Otherwise, it doesn't. An input location assumes that you can inject any frequency at that point.
that's ok! My input is Sin wave(Vin) and output is voltage across R(vout)...
A voltage source connected to a resistor has the input terminals and output terminals at the same place. Your transfer function is 1 no matter what the voltage and no matter what the resistance.. A bode plot of 1 is a horizontal line of magnitude 1 for all frequencies. That's pointless.
I think you have some conceptual problems about transfer functions, circuits, and Bode plots.
Can you tell us what you are trying to accomplish?
you are right! I understood the things now... sorry for some silly questions that mess you up!
Thanks for reply.
FAQ: Plotting Bode of Resistor w/ DC Source: 20*log(0)
1. What is a Bode plot?
A Bode plot is a graphical representation of the frequency response of a system. It shows how a system responds to different frequencies of an input signal.
2. How is a Bode plot useful in analyzing a resistor with a DC source?
A Bode plot can show the gain and phase shift of a resistor with a DC source at different frequencies. This can help in analyzing the stability and frequency response of the system.
3. What does the 20*log(0) in the equation mean?
The 20*log(0) in the equation represents the magnitude of the gain of the resistor at the frequency of 0 Hz. Since the logarithm of 0 is undefined, the magnitude of the gain at this frequency is considered to be negative infinity.
4. Can a resistor have a negative gain in a Bode plot?
No, a resistor cannot have a negative gain. The gain of a resistor is always equal to or less than 1, which corresponds to 0 dB on a Bode plot.
5. How can I interpret the phase shift on a Bode plot?
The phase shift on a Bode plot represents the amount of delay or advance of the output signal compared to the input signal. A positive phase shift indicates an advance, while a negative phase shift indicates a delay.
10K
