Books about engineering Cogweels and/or transmission
The discussion centers around developing a CNC system and the need for foundational knowledge in mechanical engineering, particularly regarding cogwheels and transmissions. Participants suggest starting with simpler projects for quicker results, such as modifying existing machines or exploring 3D printing. Recommendations include seeking out books on mechanical engineering, with a specific mention of "An Introduction to Mechanical Engineering" by Clifford, Brooks, and Howe. There is also an emphasis on gaining practical experience through courses in 3D CAD software and electronics. Overall, the conversation highlights the importance of building a solid knowledge base while pursuing hands-on projects in engineering.
MrZwing
I have recently found an intresst in thinking about and want to try to develop a CNC system or something similar with computer to mechnical hardware communication.
but i believe my knowledge about mechanical engineering feels limited and would appreciate some good general books about mechanical engineering and some good books about Cogweels and transmissions and how to calculate them prefably somting from the basic's and up.
Thank you.
/MrZ
Welcome to PF.
The project you are contemplating is a very long term project, maybe never ending.
Consider a shorter project that will provide a quick result while providing a useful tool.
3D printers are available that may get you experimenting very quickly.
To function well, machines that actually cut solids need to be very well designed by experienced engineers. Maybe modifying an available manual milling machine to CNC would be possible.
Machines that cut cloth or sheet plastic are not so heavy and may be easier to build and put to work. Likewise a large format painting machine, (paint spitting?), is a possibility as it does little physical work.
Perhaps the best way to follow your interest, and be paid to do it, would be to work for a manufacturer who uses “Wire EDM” equipment. WEDM uses 3D CNC to position a moving brass wire electrode that can cut very hard conductive materials by spark erosion.
Since you are now following your interests, it is probably best to go to a library to identify books that suit you on mechanical engineering. Used book shops have ME books, often at very low prices. Once you have identified a book and want a printed copy, you can use bookfinder.com to locate a new or used copy at the right price.
I do not know your budget so I have not suggested any particular new books.
Ask follow up questions if you require more specific answers.
Found some
Hello and sorry for the time it took for my responce
CNC is quite a heavy subject but still really interessting i have a education in CNC-operating so i have experiebce in the understanding how they work, but still not enough I am naturally extreemly curious and have an urge to know hoe thing work from the ground upp and get a bit obsessive and often end upp wanting to build a basic type just to know.
i have more ideas withing engineering so i found quite a lot of book's on the internet probably going to start with
An Introduction to Mechanical Engineering Part 1 and 2 by Clifford, Brooks, Howe
it seems very well put together but ill know for shure after i read it. haven't skimmed through the rest but i think fluid dynamics might be a bit mutch until i read upp on the basics.
going to look at some courses in some 3D CAD software too and learn some vasics there as well.
as for electronics i am currently wgating for ans answer form a 2y long course in electronics anf hope ill get in if not i also applied for Automation Engineer and will elarn electronics and MC programming in my spare time.
but i will by some papper copies when the gods of economics smile upon me sine i like the feel of books more then staring at a flickering screen.
sorry for the bad grammar and spelling english is not my native spoken or written language.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
