Bouncing Ball Problem - 2 Dimensional Challenge Lab
The discussion revolves around determining the diameter of a bouncing ball using limited information from a provided PDF and Logger Pro software. Participants express confusion over the lack of necessary data, particularly the absence of a scale for the PDF, which complicates measuring the ball's diameter. One contributor suggests finding a distance scale to convert measurements from the PDF to real-world dimensions, while another emphasizes the importance of understanding gravitational acceleration in free fall. The challenge lies in deriving useful information from the simulation without explicit details on scale or surface conditions. Overall, the conversation highlights the difficulties faced in solving the problem with the given constraints.
jambobambo
The object of the lab is to find the diameter of the bouncing ball shown in the pdf attached. We are working with Logger Pro. The only 2 pieces of information that we have is that the ball is on the surface of the earth, where Ay=-9.81 m/s2, and that the frames are 0.05 seconds apart. This does not seem like anywhere enough information to go on, since that is all the information.
I do not know where to begin this problem. I'm not sure how I could get to the end.
I've tried to reason this out, but I do not see a way that, from this little info, we can achieve the diameter of the ball. Though I could track the ball on Logger Pro, and make a graph of its path, I do not see how this will do me any good.
I do apologize for the lack of work, but I am truly stumped and lost on how to even begin on this problem. I suppose that's why my teacher called it a "challenge" lab.
Hello jambobambo,
This is an interesting problem. You stated the ball was on the surface of the earth. Does that mean that this simulation accounts for friction?
-Eric
He did not mention it, so I am assuming that, as usual, we are ignoring the friction. I think that he would have specified it if we were not.
What you have to do is to find a distance scale for the pdf you've attached. If you know how long a unit length of your pdf is in the real world, you can measure the diameter of the ball in the pdf, and convert it to a real world length.
This is true, but is there a way to find the scale factor from only the pdf? This is a quote from my instructor:
"At first glance, it will seem as if insufficient information is given, as the scale of the video is not given and the surface on which the ball bounces cannot be seen. "
I agree this is probably one of the keys, but finding a scale factor with only the pdf eludes me.
Consider the fact that, neglecting air friction, any object in free fall falls under gravitational acceleration.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
