Bouyant Force in a U Shaped Plastic Tube
The discussion revolves around calculating the height of water in a U-shaped plastic tube that will exert a force of 9.8 N on a sealed cap. The equation used is F = ρ*V*g, where the user initially used an incorrect density value of 1 kg/m³ for water, leading to an unrealistic height of 1998 m. Upon realizing the mistake, the correct density of water, 1000 kg/m³, is identified as necessary for accurate calculations. The user is focused on isolating the height variable h to determine the required water level in the left arm of the tube. The conversation highlights the importance of using correct values in physics equations to achieve realistic results.
chillpenguin
A plastic tube has a cross-sectional area of 5.00 cm^2. The tube is shaped sort of like a "U". The left arm is filled with water until the right arm of length 0.800 m is full of water. The right arm is then sealed with a cap that won't pop off until a force of 9.8 N is applied. What total height of water in the long arm (left arm) will put the seal on the verge of popping?
F = ρ*V*g (Force = density * volume * acceleration from gravity)
Trying to solve for the height h, I used the equation 9.8 N = (5.0 cm2)(1/10000 m2/cm2)(h)(1 kg/m3)(9.81 m/s2)
I'm using the value 1 kg/m3 as the density of water and 9.81 m/s2 as the acceleration due to gravity.
Isolating h, I got 1998 m, which seems way to large. I must be doing something wrong. The units work out though. I end up with meters. But the number seems way too large.
Whoops I figured it out! I should be using a water density of 1000 kg/m^3!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
