What Is the Compression of the Spring When the Box Reaches Maximum Speed?
In summary, the 17.0 kg box slides down a frictionless ramp for 4.0 m before colliding with a spring with a spring constant of 190 N/m. The maximum compression of the spring is 2.36 m. However, the maximum speed of the box occurs before it hits the spring, as the kinetic energy is converted to potential energy upon collision. The acceleration of the box is not zero at this moment, but rather starts to decrease and change direction. The correct equation to use for this problem is 0.5kx^2 = fdsin30, where k is the spring constant, x is the compression of the spring, and fd is the force of the box sliding down the incline
kliang1234
A 17.0 kg box slides 4.0 m down the frictionless ramp shown in the figure, then collides with a spring whose spring constant is 190 N/m.
Picture: http://session.masteringphysics.com/problemAsset/1000077659/2/knight_Figure_10_69.jpg
We also know:
a) What is the maximum compression of the spring? 2.36m I got this answer correct
My question is on b:
At what compression of the spring does the box have its maximum speed?
I was thinking this was a trick question. From the picture, the moment the box hits the spring, it slows down because the kinetic energy is transferred to spring potential energy. So i initially thought that the speed would be maximum right before it touches the spring. Therefore, compression of the spring would be at 0m.
That was incorrect.
Then I was thinking, maybe i was wrong and that maybe maximum velocity would be when acceleration is = 0.
To find the point when acceleration would be 0, i used:
(4m x 9.8m/s^2 x 17kg x sin(30)) = 333.2 N for work done while sliding down before hitting the spring
And we know F = kx
I was thinking that acceleration would equal 0 when kx = 333.2N because the compression would counteract the sliding down force.
With k = 190 i get x to get 1.75m
That was also incorrect
I have like 2 tries left on this stupid program.
Please someone help me out.
Before F from the string is higher than F from gravitation, box still accelerates, doesn't it?
if you meant spring, yes it still accelerates.
Thats why i thought to set kx = Fdsin30
but that was incorrect
I think I agree with your first guess. Also in that problem there is no instant in time at which acceleration is zero since the box would never remain at a constant velocity.
Acceleration would be gsin30 if I'm not mistaken.
There would be a time where acceleration will be equal to zero and that is when the retarding force of the spring pushes back onto the box until the box stops and the spring expands and the box slides back up the incline.
Both my tries seem to carry some truth in my opinion but they are wrong.
should i be doing .5kx^2 = fdsin30 instead?
kx = fdsin30 is for an instance where the spring force equals force of box sliding down the incline.
.5kx^2 would make more sense because the spring force isn't constant, there should be a summation of it so .5x^2 = fdsin30 makes sense too but I am really scared to try that answer without some guidance
Yeah, acceleration would be gsin30 when the box is traveling down the slope. The acceleration the box experiences when the spring slows it to rest is not zero. So the max velocity of the box is before it hits the spring. There is a slight difference between speed and velocity though perhaps that's the issue. Since the box is traveling down is that the negative direction?
scratch that last statement... but yeah the velocity should be max when it first comes into contact with the spring I am not sure how that isn't correct.
No. After the box comes in contact with the spring it still accelerates. At this moment it is acceleration that starts to get smaller, not the speed. When the box starts to slow down it means acceleration changed sign - that means there was a moment when it was zero. Speed was growing to that moment.
ok, so i tried .5kx^2 = fdsin30
that wasn't it either. I'm down to my last try on masteringphysics :cry:
nevermind.. after thinking about it some more, i finally got it
Im curious what did you find the answer to be?
Related to What Is the Compression of the Spring When the Box Reaches Maximum Speed?
1. How does the angle of the incline affect the motion of the box and spring?
The steeper the incline, the faster the box and spring will move down the incline. This is because a steeper angle increases the component of gravity acting on the box and spring in the direction of motion.
2. What is the role of friction in the motion of the box and spring on an incline?
Friction plays a significant role in slowing down the motion of the box and spring on an incline. As the box and spring move down the incline, friction between the box and the incline surface acts in the opposite direction, causing the box and spring to slow down.
3. How does the mass of the box and spring affect its motion on an incline?
The mass of the box and spring does not affect the motion on an incline as long as there is no external force acting on it. According to Newton's Second Law, the acceleration of an object is directly proportional to the net force acting on it, and inversely proportional to its mass.
4. What happens to the motion of the box and spring if the incline is frictionless?
If the incline is frictionless, the box and spring will continue to move down the incline at a constant speed. This is because there is no external force acting on the box and spring to change its speed or direction.
5. How can the energy of the box and spring on an incline be calculated?
The total energy of the box and spring on an incline can be calculated using the conservation of energy principle. The initial energy of the system (potential energy at the top of the incline) is equal to the final energy of the system (kinetic energy at the bottom of the incline).
